Carb balancing in or near Newbury / reading
Beastieboy
#1 Carb balancing in or near Newbury / reading
Post by Beastieboy » Fri Jul 06, 2012 8:01 pm
Hi, I need to find a decent garage with experience of balancing triple carbs, checking mixture etc
Recommendations welcome Please message me direct if you want to avoid advertising if that is an issue
Woolfi
Post by Woolfi » Mon Jul 09, 2012 9:21 pm
Checking mixture at iddle or speed ? This can be a big difference , IF the exhaust or the air-filter system has been changed.
A garage normally is measuring the mixture at idle. Are you driving with iddle ? No !
A needle profile of the carb-needles is fitting to the motor, if there have been no or only minor changes in the "motor-system".
Regards Wolfgang Gatza
snowdmc
Post by snowdmc » Tue Jul 24, 2012 11:48 am
Thomas Barclay at Gerrards Cross balanced my v12 and is an etype specialist, so should be able to help - only a short distance past reading, near uxbridge
