Forum Access Problems
#41 Re: Forum Access Problems
Post by Heuer » Fri Jul 22, 2016 6:14 pm
No, I have disabled the remove the 'Remember Me' after XX days feature so you should always be logged back in automatically. Certainly works for me. Have you tried deleting the board cookies using the link at the bottom of the page? Also which browser are you using? Please try a different one just to check things out.
Nickleback
#42 Re: Forum Access Problems
Post by Nickleback » Sat Jul 23, 2016 6:31 am
Thanks for the suggestions David.
Tried deleting all board cookies overnight - it didn't work. Browser I'm using is Firefox in auto secure setting (HTTPS).
Will try a different browser Sunday tonight when I'm back to see what happens
Mike,
1970 S2 FHC 2R28165
Durango2k
#43 Re: Forum Access Problems
Post by Durango2k » Sat Jul 23, 2016 7:45 pm
I seem to have some problems with the templates- I only get we_universal and ProSilver.
Has something changed ? It looks different then it did the past 5 weeks....
Carsten
#44 Re: Forum Access Problems
Post by Heuer » Sat Jul 23, 2016 9:08 pm
Durango2k
#45 Re: Forum Access Problems
Post by Durango2k » Sat Jul 23, 2016 9:31 pm
Thanks for showing me,
But both don't have the "unread posts" quicklink ? It is behind the menu button...
Carsten
#46 Re: Forum Access Problems
Post by Heuer » Sun Jul 24, 2016 11:20 am
Depends on which 'style' you have selected which is why I am going to get everyone using the same one very shortly - multiple choice of styles is becoming a support nightmare!
I am guessing you are one of the five members using 'prosilver special edition' and that hides the quick links in a hamburger menu:
Suggest you change the style to we-universal in your User Control Panel. It makes the Forum much more user friendly I think.
Durango2k
#47 Re: Forum Access Problems
Post by Durango2k » Sun Jul 24, 2016 11:53 am
Am now back to we_universal. I you use an iPad, its a bit cluttered when you also have the favorites menu on- the screen becomes a bit small. But it works in full screen mode.
Carsten
Nickleback
#48 Re: Forum Access Problems
Post by Nickleback » Mon Jul 25, 2016 8:42 pm
Nickleback wrote:Thanks for the suggestions David.
I have now tried a different browser (Microsoft Edge) & the problem has gone away, so it is clearly an issue with Firefox high security browsing using HTTPS settings.
I have now disabled Kasperky add-on Smart HTTPS in Firefox so that it remains in HTTP which was the issue, now I stay logged in on HTTP but not on HTTPS.
Mike,
1970 S2 FHC 2R28165
Polse7317
#49 Re: Forum Access Problems
Post by Polse7317 » Wed Oct 05, 2016 11:48 am
Hi, i don't know how to change my password ? i can only use the one given automaticaly : n zjebn4ezadv5vaev ....... !
Where could i change it?
neil4444
#50 Re: Forum Access Problems
Post by neil4444 » Wed Oct 05, 2016 12:37 pm
Hover over your username (top right) then select profile.
On profile screen select edit profile (top middle of screen by username).
HTH
Neil
1962 S1 OTS
1967 S1 FHC
Polse7317
#51 Re: Forum Access Problems
Post by Polse7317 » Wed Oct 05, 2016 12:43 pm
Thank's Neil :salute:
Red Kite
#52 Re: Forum Access Problems
Post by Red Kite » Wed Oct 05, 2016 12:44 pm
My existing password wouldnt work and its not visible if you cant log in ...
I used forgotten password link to get a new one.
Gerry.
S2 FHC 1R20003
#53 Re: Forum Access Problems
Post by Heuer » Wed Oct 05, 2016 12:51 pm
I am finding a few gremlins such as the National Flags at the bottom of the home page do not display and I seem to have to log on every time rather than having the login retained. I will investigate but I think it may be the wrong version of SQL which is the problem.
AussieEtype
#54 Re: Forum Access Problems
Post by AussieEtype » Wed Oct 05, 2016 1:08 pm
I have transitioned across - no issues at all. :bigrin:
Garry
1971 Series 3 E-type OTS
1976 Series 2 XJ 12 Coupe
AussieEtype
#55 Re: Forum Access Problems
Post by AussieEtype » Thu Oct 06, 2016 1:50 am
Spoke too soon - was remembering me yesterday but I am now having to login each visit today - the remember me box is ticked - I assume that is not working.
#56 Re: Forum Access Problems
Post by Heuer » Thu Oct 06, 2016 9:46 am
Should be fixed now. Please go to your browser settings and delete cookies and try logging on again.
#57 Re: Forum Access Problems
Post by christopher storey » Thu Oct 06, 2016 4:48 pm
I can get in now without logging on, but have found that a post I made does not appear . Strange . I shall give it some time to settle down
edit : even stranger .... this one has appeared perfectly, so apparently all is well
AussieEtype
#58 Re: Forum Access Problems
Post by AussieEtype » Fri Oct 07, 2016 2:29 am
My login is now working Ok. Just a matter for the little bugs to be worked through but the basic forum is working fine for me - thanks.
Garry
#59 Re: Forum Access Problems
Post by Heuer » Fri Oct 14, 2016 10:01 am
There seems to be a problem with accessing Photobucket (or at least some of their servers) at the moment which means photos and avatars may not display correctly in posts. You will see a small coloured square instead of the photo. I will chase it up with Photobucket.
Tbob
#60 Re: Forum Access Problems
Post by Tbob » Fri Oct 14, 2016 10:16 pm
David, I have PMs stuck in my out box. I can't figure out how to get them to move on. Any advice? Hope its just an operator error.
Sorry for the use of public bandwidth, but I can't send you a PM!
Bob t
Bob t
LHD '69 OTS. (Former) basket case
