Rubber jack pads
#1 Rubber jack pads
Post by mgcjag » Wed Aug 09, 2017 3:00 pm
Hi All....was looking for some rubber pads to use in a trolly jack and to use with my car lift.....for some reason all the auto shops are quite expensive for a rubber pad.....then someone put me on to ice hockey pucks perfect size 75mm diameter and 24mm thick solid rubber and only £1.50 each Steve
https://www.skatehut.co.uk/brands/6030_ ... gIXRfD_BwE
#2 Re: Rubber jack pads
Post by Gfhug » Wed Aug 09, 2017 3:08 pm
:yellow:
PhilP
#3 Re: Rubber jack pads
Post by PhilP » Mon Aug 14, 2017 7:39 pm
Thanks for the tip I've been looking for some rubber pads for my jacks ive just ordered 4 from your link
Thanks again
1968 series 1.5 fhc, Ftype S for when it rains
JagWaugh
Switzerland
#4 Re: Rubber jack pads
Post by JagWaugh » Mon Aug 14, 2017 7:49 pm
If you cut 3 pucks in half and screw them on a board at the spacing of the valves you've got a great board for fitting valve springs.
