#1 Demister Hose
Posted: Fri Oct 13, 2017 7:45 pm
by jagwheels
Hi Does any one know where to get the proper plastic flexible hose for demister that joins the Y pieces and the demister nozzles.
Regards John
#2 Re: Demister Hose
Posted: Sun Oct 15, 2017 3:53 am
by E600
I believe it's available from SNG, however, if not a sticker for originality look to vacuum cleaner repair shops. There are hoses of similar diameter that fit the bill for a fraction of the cost.
For one rebuild, I found a cleaner hose at my local tip when dumping rubbish!
#3 Re: Demister Hose
Posted: Sun Oct 15, 2017 10:16 am
by jagwheels
Thanks for the tip. that is exactly what I need.
#4 Re: Demister Hose
Posted: Sun Oct 15, 2017 10:21 am
by JagWaugh
Also try a Camper or Ship's chandlers if you've got one local. They sometimes stock tubes for heating distribution (although campers are usually a larger diameter).
#5 Re: Demister Hose
Posted: Sun Oct 15, 2017 1:48 pm
by Moeregaard
Another possibility is CAT ducting, which is widely used in the aviation industry. More expensive than vacuum-cleaner hose, but it's really flexible and you'll never need to replace it again.
