Hi Does any one know where to get the proper plastic flexible hose for demister that joins the Y pieces and the demister nozzles.
Regards John
Demister Hose
#2 Re: Demister Hose
I believe it's available from SNG, however, if not a sticker for originality look to vacuum cleaner repair shops. There are hoses of similar diameter that fit the bill for a fraction of the cost.
For one rebuild, I found a cleaner hose at my local tip when dumping rubbish!
#3 Re: Demister Hose
Thanks for the tip. that is exactly what I need.
John Gill
1966 FHC SWB
1966 FHC SWB
#4 Re: Demister Hose
Also try a Camper or Ship's chandlers if you've got one local. They sometimes stock tubes for heating distribution (although campers are usually a larger diameter).
Moeregaard
#5 Re: Demister Hose
Another possibility is CAT ducting, which is widely used in the aviation industry. More expensive than vacuum-cleaner hose, but it's really flexible and you'll never need to replace it again.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
