triple carb rebuild
purplefiz43
#1 triple carb rebuild
Post by purplefiz43 » Thu Dec 14, 2017 12:26 am
just finished these su carbs and manifold rebuild for a customer
EKelly96
#2 Re: triple carb rebuild
Post by EKelly96 » Mon Dec 18, 2017 10:19 am
Looks good, thanks for sharing. I need to rebuild mine in the near future, luckily it's not that urgent.
jamie101
#3 Re: triple carb rebuild
Post by jamie101 » Wed Dec 27, 2017 10:50 pm
They look fantastic! Great job that man!
What would this cost me of i were to send my tripple SU's and let you rebuild them?
They are on my car and they are running at the moment but i think theyre getting to the point of needing a refurb now i recon.
Thank you. J
#4 Re: triple carb rebuild
Post by mgcjag » Thu Dec 28, 2017 8:36 am
Hi Jamie.....have a look at this thread viewtopic.php?t=275 you will see that it mentions David Lonsdale....he is very well known to many forum members....and his carb rebuilds are second to none....he also provides parts and will give assistance to anyone rebuilding there own... Steve
jamie101
#5 Re: triple carb rebuild
Post by jamie101 » Thu Dec 28, 2017 1:33 pm
Thank you for that information. Ill have a read at that in a min.
Following up your misfire you had on yours a while ago, did you ever get that sorted?
If you remember it was back in 2015 when i was gunna use mine for my wedding but i had a slight vibration/misfire!
#6 Re: triple carb rebuild
Post by mgcjag » Thu Dec 28, 2017 2:19 pm
Hi Jamie...after changeing out everything it turned out to be a lose crimp on the low tension wire on the coil.. Steve
jamie101
#7 Re: triple carb rebuild
Post by jamie101 » Thu Dec 28, 2017 10:21 pm
Wow just goes to show one little thing like that can cause pain in the neck problems!
