Tips for Laying Cars Up for the Winter
Car-Nut
#1 Tips for Laying Cars Up for the Winter
Post by Car-Nut » Sun Oct 25, 2009 2:47 pm
This thread may be good to be a sticky, David.
Anyway over to you guys on this one as Im new to this.....
Though, hopefully I will be using mine through the winter when the conditions are fit :)
Post by Heuer » Sun Oct 25, 2009 4:15 pm
1. Brim fuel tank
2. Pump up tyres to 40psi
3. Attach battery conditioner/tricklecharger
4. Check coolant level and correct anti-freeze ratio
5. Start engine and run up to operating temperature every couple of months
6. Move car forwards/backwards 12" every month to avoid tyre flat spots
7. Leave 2" gap in side windows for ventilation
8. Dust paintwork down with Nenette duster (Nenetol treated)
9. Use a dehumidifier if possible (B&Q sell good cheap ones)
Car-Nut
Post by Car-Nut » Sun Nov 01, 2009 6:02 pm
Post by Heuer » Sun Nov 01, 2009 7:19 pm
Interesting link Clive especially the bit about leaving the handbrake off - I forgot that one.
Car-Nut
Post by Car-Nut » Sun Nov 01, 2009 7:52 pm
Heuer wrote:Interesting link Clive especially the bit about leaving the handbrake off - I forgot that one.
and the mousetraps, critters had been in mine sometime when the PO had it. All nut shells under the drivers seat when I took the carpet out :!:
Kraut
Post by Kraut » Fri Nov 06, 2009 3:26 pm
Heuer wrote: 5. Start engine and run up to operating temperature every couple of months
For my opinion, this is absoultely unnessesary and by the way, it is not good for the engine.
Car-Nut
Post by Car-Nut » Fri Nov 06, 2009 3:43 pm
Welcome to the forum Kraut...
Im sure ive read something like that, doesnt it leave a load of moisture in the exhaust as well and starts internal rusting :shock:
Mark Gordon
Post by Mark Gordon » Fri Nov 06, 2009 7:33 pm
Starting the engine and running for a minute or so wouldn't be good, but if you let it get up to operating temperature, the water and gasoline vapors that can get into the oil would have a chance to evaporate via the crankcase breather system and should not be left to start rust problems. I had a Spitfire that I used to start and warm up like that during the winter (I had it for about 27 years from new) and never had any internal engine problems in about 150,000 miles.
