#1 Metalifacture jack - Knurled screw and Spring Clips
Posted: Mon May 28, 2018 3:56 am
At the weekend I had cause to inspect my jack in the S2 FHC. I'm pretty sure it is the original Metalifacture jack.
At the bottom of the bag I found the knurled circular disc that you can use to raise and lower the jack, plus 2 spring clips, which presumably are designed to secure aforementsioned knurled disc.
The spring clips seem designed to lock securely to the square end of the jack shaft. However, mine do not even touch the sides of the sqaure shaft, presumably the reason for knurled disc falling off.
I believe these spring clips are available from Richard Smith, but I would be very pleased to hear how they are fitted and the orientation of the 2 dished spring clips (and why there are two...)
many thanks in advance
