Post
by Echezeaux » Sun Aug 02, 2009 11:47 am
Hi Car-Nut
My piece of wood for the rear jacking point ( under the diff ) with the exhaust on measures :
45cm X 8 cm or 18'' X 3''
I found that the exhaust line from the manifolds to the end was really easy to remove and refit as one piece.
I removed it twice to change oil in the G/box and to fix an oil leak on the right angle speedo drive, so easy to work and you can see what you do !! And nearly no swearing !
Until now I haven't replaced the exhaust ring seals once, I just smeared them with copper sealant and Bingo,no leaks, you just need to jack up the car high enough. Anyway, you need to be able to move comfortably under a car. And like me , you can even have a beer laying underneath your car, gazing at the bits & pieces and making plans for the future !
On the same topic, I found that if you support your car under the sils like I show in the 5th picture, the floor can cave a bit. Be careful!.
And thanks for the appreciation of the post.
Thierry
3.8 RULES
I want to die peacefully in my sleep, like my grandfather,not screaming and terrified like his passengers.
