Page 1 of 2
#1 Electric power steering
Posted: Sat Jan 11, 2020 4:30 pm
by Etype Maria
Hi. Has anyone on here had experience in use or fitting of the EZ power steering system ( I think their a Dutch company).
Thanks for any advice.
#2 Re: Electric power steering
Posted: Sat Jan 11, 2020 6:06 pm
Have a look here... viewtopic.php?f=3&t=10580
#3 Re: Electric power steering
Posted: Sat Jan 11, 2020 8:56 pm
by chrisfell
Nope, but I have driven a S1 with power steering by Lite Steer. It worked when it was required, and not when it wasn’t. Lite Steer is £2k, from memory EZ is....er...not!
#4 Re: Electric power steering
Posted: Sun Jan 12, 2020 11:33 am
by lestere
A friend of mine has just fitted this system to a TR7 and is pleased with the outcome.
He said there were no problems with the fitting. The amount of assistance is adjustable and nothing is visible under the bonnet.
#5 Re: Electric power steering
Posted: Sun Jan 12, 2020 7:29 pm
by MarekH
Go and search one of the e-type club magazines for an article by Rod Shears on this subject. He has fitted electric steering to a number of Jaguar cars and I think the donor parts were from a old Maestro. Total cost will leave you with £1800 more in your pocket than if you go down the £2000 route mentioned above.
#6 Re: Electric power steering
Posted: Mon Jan 13, 2020 3:09 pm
by chrisfell
I've been trying to keep this comment to myself, by I cant keep it in any longer. :bigrin:
Protein shakes and working out with weights is cheaper, and the benefits can be used elsewhere.
#7 Re: Electric power steering
Posted: Wed Jan 15, 2020 10:53 am
by Kember17
chrisfell wrote: ↑
While that is certainly true for me, my wife, for one, would object to having to develop arms like a navvy's simply to move the car out of its parking spot, and I didn't marry her for her resemblance to Charles Atlas either :smile:.
#8 Re: Electric power steering
Posted: Wed Jan 15, 2020 11:10 pm
by bitsobrits
I have installed the EZ power steering in my S1 E type several years ago, and it certainly helps with low speed maneuvers as I run 6.5" wheels with 215 section tires.
However...
I did my own install and found it impossible to get the steering column (the upper section of which is replaced by the EZ unit) mounted fully in the "up" position, which is where I preferred it before. Due to the mounting design, the column now has a slightly flexible quality which I greatly dislike.
Additionally, the system only provides assist when needed, i.e. when it detects increasing load in your steering inputs. At parking lot speeds this is fine. But in certain conditions, generally medium speed (50-70 mph) corners or decreasing radius corners, you can enter the corner with no apparent assist, then when beginning to accelerate at the apex, the assist comes in with the effect of causing a bit too much steering lock, to which you have to adjust. This effect is fairly subtle, not unsafe in any way, but very annoying, and certainly doesn't give one confidence in the car's tracking. The system is adjustable, and turning it full down helps, but ultimately I put in a discreet on/off power switch which cured the handling ills. Now I turn it on for parking work, then off as soon as I'm up to speed.
I really am contemplating removing it entirely.
#9 Re: Electric power steering
Posted: Fri Jan 17, 2020 12:25 pm
by markc555
MarekH wrote: ↑
Interesting :geek2: Any idea which magazine edition number Marek? I wouldn't mind a read.
I've seen Vauxhall Corsa EPS systems retrofitted to a number of cars but not an E Type.
#10 Re: Electric power steering
Posted: Fri Jan 17, 2020 12:32 pm
by Kember17
markc555 wrote: ↑
MarekH wrote: ↑
I thought the Corsa executions were a mite dangerous as they appear to rely on spoofing the unit to believe certain inputs that might not properly accord to real data.
I'm experimenting with the MGF system and am planning to use "real" inputs.
I have some photos of the modified steering column somewhere and some details of the bits of kit needed but my project is slightly stalled owing to illness at the moment. I'll see what I can dig out.
IIRC, labour apart, the cost of the various bits of kit is considerably less than £100.
Peter
#11 Re: Electric power steering
Posted: Fri Jan 17, 2020 5:24 pm
by MarekH
I have no idea which edition of which club magazine it was, although Rod did give me a .pdf copy some years ago. His name will pop up if you ask around. If you get stuck, I can dig out an email address held on another computer somewhere.
It may well have been a MGF now that is mentioned - my memory on this is a bit hazy as I have a s3 so am not incentivised to remember the exact details. I remember the parts were £50-£60 from a scrapyard and the cars were plentiful.
#12 Re: Electric power steering
Posted: Mon Jan 20, 2020 11:26 am
by markc555
No worries Marek.
I did google "Rod Shears" and as you can imagine got some interesting and dramatic tales and pics of structural failure rather than the man himself :lol:
#13 Re: Electric power steering
Posted: Wed Feb 12, 2020 8:15 pm
by MarekH
He lives in Walton.
PM me your email address and I'll send it on to him.
#14 Re: Electric power steering
Posted: Thu Feb 13, 2020 6:24 am
MarekH wrote: ↑
He lives in Walton.
If you guys come up with some concrete information about how to do this could you do a write up here? For that sort of outlay I'd try it just for the exercise.
#15 Re: Electric power steering
Posted: Thu Feb 13, 2020 10:12 am
by politeperson
I am in the middle of doing a Corsa B steering box conversion.
The unit itself is GM, probably fitted to millions of cars and is small and looks very robust. It is self contained and has an internal ECU.
It requires a control box which is programmable for the speed inputs. I bought one some time ago for £90.
The speed inputs are produced from a windmill and a hall sensor. I will probably fit that on the gearbox end of the prop. It also requires a power input which no doubt will involve a high current relay triggered input. That is it.
The control box has 3 settings, full assistance, medium and no assistance.
I was going to programme it to provide full assistance up to 2mph, medium up to 10 mph then it would provide no assistance over that speed.
So it would just be for manoeuvring.
My concern is that is it might create friction in the steering system, so I might lose self centering. I dont think it can be that bad, as the unit probably compensates for its own internal friction. I dont know yet.
I have got as far as mounting the unit on an old bulkhead assembly. I was going to extend the column with old MK2 Jag columns I have, to replicate the original units length. That means I will also have Jag splines for the steering wheel.
The whole cost of this so far is £250. I will post some pictures if I get a moment.
#16 Re: Electric power steering
Posted: Fri Feb 14, 2020 7:10 am
by markc555
Good info James, I’d be interested to hear how you get on.
There’s some good information here (http://www.super7thheaven.co.uk/corsa-e ... g-kit-car/) particularly on the controller side of things and how to set them up :geek:
#17 Re: Electric power steering
Posted: Tue Sep 28, 2021 6:15 am
by MarkRado
bitsobrits wrote: ↑
I have installed the EZ power steering in my S1 E type several years ago, and it certainly helps with low speed maneuvers...
I am contemplating an ez system as well
Can you please explain what is the difference in design? I thought it is a straight swap. Any deviation would be a horror,
thank you
#18 Re: Electric power steering
Posted: Tue Mar 22, 2022 2:47 pm
by RogerHicks
Hi, we can help, look us up, Power Steering Solutions on Facebook.
#19 Re: Electric power steering
Posted: Thu Mar 24, 2022 7:36 pm
by gtjoey
4,000 miles in the last 4 or 5 months.
Its a game changer.
1967 etype coupe.
Love it.....
Its an updated model with speed sensitive.
It transforms the car toa 1990 ish feel ALOT BETTER.
Iput 10,000 miles a year.......
I love the ez.....
gtjoey1314
#20 Re: Electric power steering
Posted: Mon May 18, 2026 7:57 am
by Bitsilly
Me too, a doddle to fit and latest version is superb.
