#1 Fuel Type (E-Type Series 3 V 12)
Posted: Sun Jun 14, 2020 10:23 pm
by Marco
This might be silly question, but I couldn't find a complete and satisfying answer. I own a 1971 Jaguar E-Type Series 3 V12 and I was wondering what is the best fuel (RON) to use or what combination of fuel and additives is the best. I would appreciate if I can also have the names of these products.
Thank you very much!
#2 Re: Fuel Type (E-Type Series 3 V 12)
Posted: Mon Jun 15, 2020 2:40 am
by 42south
hi
Just use 95RON as the minimum.
My owners handbook specifies minimum 98RON.
However I have always used 95RON with no visible adverse effects when I rebuilt the engine, after 20 years of use. Maybe if you intend to race, or drive like a race driver then 98 would be best, otherwise 95.
I have never used any additives, the engine does not require any. The valve seats are already hardened and non lead gasoline is fine.
#3 Re: Fuel Type (E-Type Series 3 V 12)
Posted: Mon Jun 15, 2020 3:03 am
by AussieEtype
Assuming you have a UK spec engine which has 9.1:1 comp ratio then 95RON (Uk RON not US RON) will be suitable. If it has the lower compression ratio engine that went to the US (7.9:1???) then 91 RON would be OK.
I believe the letters at the end of engine number indicate whether hi (SA??) or low comp (??)
Garry
#4 Re: Fuel Type (E-Type Series 3 V 12)
Posted: Tue Jun 16, 2020 12:29 pm
by Marco
Thank you all for your replies!
