Purchasing and freight forwarding
lowact
#1 Purchasing and freight forwarding
Post by lowact » Wed Feb 10, 2021 7:57 am
I see we have 12 Polish members.
Ok, so I need a tank for my e-type petrol to propane conversion. I want a Stako W36008508 which is 85 L and designed to accommodate a Vialle LPi pump. Not easy to find.
Stako (Polish company) suggest I should buy it from Vialle (Netherlands company). Vialle consider one tank delivery to Australia would be too expensive.
Meanwhile I have found a potential retailer – in Poland:
http://www.sklep-lpg.com/vialle-zbiorni ... p-393.html
I’ve tracked this down to a smart looking residence in downtown Wegrzce. Their cost to deliver to Australia is brutal.
Fortunately, there is a very prominent Polish parcel forwarding service:
https://www.parcelpoland.tk/
Their cost to forward the tank to Aust. is more reasonable, although still more than the cost of the tank. However, PFP seems to be a one person operation, using a pseudonym and false portrait images (LinkedIn). The address I would need to send the 40 kg tank sent to is the 11th floor of a residential apartment block in Radom.
What to do …
ysmalkie
Poland
#2 Re: Purchasing and freight forwarding
Post by ysmalkie » Wed Feb 10, 2021 10:01 pm
Collin, Contact me offlist - I think I might be able to help :-)
If it's the same Wegrzce, then it's 5 min away from me.
Regards, Tadek
Tadek
Jaguar XK120 OTS
Austin-Healey 100 BN2
ysmalkie
Poland
#3 Re: Purchasing and freight forwarding
Post by ysmalkie » Wed Feb 10, 2021 10:04 pm
Also, contact Marek - he did a LPG conversion, buying parts in Poland and might be able to advise...
I did a LPG conversion on my Range Rover 20 years ago, this was the last time I had contact with LPG - it's very popular here though and technology has moved since then.
Tadek
Tadek
Jaguar XK120 OTS
#4 Re: Purchasing and freight forwarding
Post by abowie » Thu Feb 11, 2021 2:00 am
Make sure it meets Australian ADRs or you may have trouble with registration.
lowact
#5 Re: Purchasing and freight forwarding
Post by lowact » Tue Feb 16, 2021 10:22 am
Hello Tadek thank you very much for offering to assist, you are very generous. Unfortunately, there has been a set-back, I can buy the tank however the freight forwarding agent has decided he cannot deliver. So now I must find another way …
ysmalkie
Poland
#6 Re: Purchasing and freight forwarding
Post by ysmalkie » Tue Feb 16, 2021 11:11 am
can you let me know the weight and dimensions of the tank as well as the region in Australia where you would wish it to be delivered?
I can enquire for delivery here.
T.
Tadek
Jaguar XK120 OTS
lowact
#7 Re: Purchasing and freight forwarding
Post by lowact » Wed Feb 17, 2021 5:58 am
Thanks Tadek. I have sent you a PM.
lowact
#8 Re: Purchasing and freight forwarding
Post by lowact » Tue Apr 13, 2021 2:10 am
Woohoo, tank has arrived, all the way from Poland!
Thanks to this Forum, in particular Tadek (ysmalkie) who went out of his way to assist, including visiting and reassuring the seller when their unfamiliarity with export outside the EU was threatening to derail the trade.
Massive thanks Tadek, I hope there is some way I can repay you.
ysmalkie
Poland
#9 Re: Purchasing and freight forwarding
Post by ysmalkie » Tue Apr 13, 2021 3:54 pm
No problem Colin! :-)
Tadek
Jaguar XK120 OTS
