Aluminium strip at the bottom of the door cards
Topic author - Posts: 162
#1 Aluminium strip at the bottom of the door cards
My series 1 2+2 has a 1 inch deep aluminium strip along the bottom edge of the door cards. It is held in place with csk self tappers.
I cannot find it in the parts book. Should t be there ?
#2 Re: Aluminium strip at the bottom of the door cards
Hi Steve, nice meeting up with you the other week, Barrie has just finished covering the door cards and he had bought the new ali trim strip you mention however, I think they are only about a 1/2" deep and sit about 4-ish inches from the bottom of the card. I may see him over the w/e, so I'll ask where he got them.
The doors are all finished now and even drilled the skins and fitted the key barrels thanks to the measurements we took of yours, little bit of sweating going on while doing it! but work perfectly and no scratches on the paintwork ha ha! just finishing trimming up some of the small fiddly bitsat the moment so should be fitting out the interior soon.
Technical Adviser to a
S1 2+2 4.2
1966
S1 2+2 4.2
1966
#3 Re: Aluminium strip at the bottom of the door cards
Hi Steve....i havent heard of an ali strip before....is it just fixed to the door card with the screws?..wasnt on my S2 2+2..can you post a photo......what is it doing?..........Steve
#4 Re: Aluminium strip at the bottom of the door cards
not on my S2 2+2 either
#5 Re: Aluminium strip at the bottom of the door cards
Thanks for the replies.
I have found a photo of the aluminium strip on my car. Its just above sill level. I do remember seeing a car with something similar many years ago. The self tappers that hold it in place go through the door card and onto the door. Seems daft to me as there are clips to hold the card in place. Just something that was fitted by a previous owner when his card and clips became soggy?
Series 1 2+2.
Series 1 2+2.
#6 Re: Aluminium strip at the bottom of the door cards
- Attachments
- IMG_20210502_101718.jpg (16.43 KiB) Viewed 3104 times
#7 Re: Aluminium strip at the bottom of the door cards
Don't think it is attatched with screws but a fastener from the back of the card so no fasteners show on the interior side, I'll double check. The doorcards previously had them fitted but were slightly damaged so he bought a pair of new by going through the parts book.
Edit: Just had a look at your pic Steve, and that seems to be the same strip.
S1 2+2 4.2
1966
S1 2+2 4.2
1966
#8 Re: Aluminium strip at the bottom of the door cards
An just as a point of interest, Steve & I are talking about S1 2+2, not S2.
S1 2+2 4.2
1966
S1 2+2 4.2
1966
#9 Re: Aluminium strip at the bottom of the door cards
Hi Steve...more details of the new parts would be good...do you have the part number?.....Steve
#10 Re: Aluminium strip at the bottom of the door cards
Hopefully I will get over tomorrow and take a decent photo back & front and see if he still has the part number, he only got them recently so fingers crossed. Also I must say that they do look very good on the cards and break it up nicely.
S1 2+2 4.2
1966
S1 2+2 4.2
1966
#11 Re: Aluminium strip at the bottom of the door cards
I have just had a look at 1966 JAGUAR E TYPE S1 2+2 MANUAL UK RHD on e-blag item no 254960290343 and the interior photos plainly show the ali strip, so I am not sure what the mystery is about them?
S1 2+2 4.2
1966
S1 2+2 4.2
1966
#12 Re: Aluminium strip at the bottom of the door cards
Hi Steve....this is a photo from the ebay add.....i can only see a chrome door trim....cant see an alloy trim on the bottom edge of the door card ....Steve
#13 Re: Aluminium strip at the bottom of the door cards
Hi all. I have the CHROME trim that is about 4 inches above the bottom of the door . I have the clips that hold it on.
If you look at the photo I posted you will see that there is an aluminium strip about 1 inch deep that is at the bottom of the door just above the sill. Its this one that I am querying.
#14 Re: Aluminium strip at the bottom of the door cards
Ahhh, your photo is not to clear Steve but now that you have said you have the chrome strip (Which is what I mistakenly thought you were talikng about) I can just see a light coloured strip that looks to me as if it is on the sill. because I have been researching a huge amount about the interior trim, looked at hundreds of photos, I believe (In my limited experience of E's) that the strip is unique to your car and my have been added by a P/O.
Sorry if I caused confusion!
S1 2+2 4.2
1966
S1 2+2 4.2
1966
#15 Re: Aluminium strip at the bottom of the door cards
Definitely not a Jaguar part.
If I were going to put a metal kick strip on I'd do it up to the chrome bead, hot half and half,
