What Diameter Safety Wire
mxke
#1 What Diameter Safety Wire
Post by mxke » Fri May 21, 2021 5:11 am
What diameter safety wire is used on our Jags? 0.025” ?
Thank you in advance.
Mike
44DHR
#2 Re: What Diameter Safety Wire
Post by 44DHR » Fri May 21, 2021 10:07 am
Hi Mike,
You don’t specify which bolt on the car you wish to lock. It generally would depend on what size and torque of fixing you are trying to lock to prevent them undoing.
0.025” is on the thin size to me, but it needs to be a good quality lock wire.
This what I use when working on E Type back axles and brakes which is 0.032”, which once properly spun up gives a nice overall diameter :-
Dave Rose
1967 Series 1 4.2 FHC
#3 Re: What Diameter Safety Wire
Post by Gfhug » Fri May 21, 2021 10:47 am
:yeahthat:
I agree with what Dave says and from my previous aviation experience I've seen a lot of poor or incorrect wire locking on E Type IRS. This could help you:
http://continental.aero/xPublications/x ... ives/10-3/
#4 Re: What Diameter Safety Wire
Post by abowie » Fri May 21, 2021 11:03 am
The original stuff on the IRS bolts is 40 thou. Not sure about the brakes and the cam bolts.
None of the wires on the E Type should ever actually see any strain, as long as you wire them correctly, as stated above. How you tie it is a lot more important than the diameter of the wire. Just pick one that goes through the holes.
mxke
#5 Re: What Diameter Safety Wire
Post by mxke » Fri May 21, 2021 2:38 pm
I will stop into my local aircraft parts supply and pick up some proper sized safety wire.
Thank you all for your help!
Mike
