Does anyone have any experience with either an Automotech AS7530 or AS7630 scissor lift for an E Type SWB?
I have limited garage height, need to be able to drive over it and could do with it being mobile. Unfortunately I don’t have room for either a 2 or 4 post.
Any advise would be appreciated
Thank you
Scissor Lifts
Topic author - Posts: 170
#1 Scissor Lifts
Simon Brown
1998 XK8 Coupe
2008 Mazda MX-5 2.0 Icon
1991 Mini Cooper 1.3i
1998 XK8 Coupe
#2 Re: Scissor Lifts
Hi Simon...great that your looking at these since our chat at C70 Gaydon.....the c7530 is the one that a friend has...very usefull tool giving center access under the car....he,s used it to remove engine and irs...... the 7630 is i think less usefull due to the cross members and center rams..............basically the 7530 is left in position all the time as to park you just drive on and over it.....Steve
#3 Re: Scissor Lifts
Questions about the 7530: how does it support the car? Looks too short to support the wheels or is there a way to extend the platform to lift the wheels? Otherwise lifting on the monocoque and wheels left dangling?
Thanks for any knowledge/experience
#4 Re: Scissor Lifts
Hi Geoff.....lift as you would with a 2 post...blocks on the platform to lift at strong points. ....radius arm bushes....chassis rails.....front bulkhead etc.....put timbers across the 2 platforms.......lots of options....wheels hang down on lift as on a 2 post.....Steve
#5 Re: Scissor Lifts
Thanks, Steve.
