#1 Number plate reclaimed
Posted: Sun Mar 06, 2022 9:25 am
by KevinJ
Dear All
After two years of effort and a couple of trips to the US I finally assembled sufficient proof of my S1 FHC original registration to satisfy the DVLA. The car 860084 was exported to the US in 1962 and remain in RHD format through its life, returned in 2000’s and restored. Now registered ODX950.
I am now facing the daunting task of removing the front stick on plate ! Anyone any advice on this?
Kevin
#2 Re: Number plate reclaimed
Posted: Sun Mar 06, 2022 9:30 am
Hair dryer....gently warm it up.....Steve
#3 Re: Number plate reclaimed
Posted: Sun Mar 06, 2022 11:57 am
by KevinJ
Thanks Steve, will give it a try
#4 Re: Number plate reclaimed
Posted: Mon Mar 07, 2022 10:12 am
by Monkeyfinger
I believe fishing line/dental floss can be used to remove badges - don't see why this wouldn't help with the number plate adhesive using appropriate 'sawing' action...
#5 Re: Number plate reclaimed
Posted: Mon Mar 07, 2022 12:27 pm
by JerryL770
As Steve says.
Warm it up and pull on the plate gently. Pull firmly but slowly, take your time to ensure you do not rip the plate. When you have it off, use the plate to remove any glue which has stayed on the bonnet by dabbing the sticky side onto it and pulling off sharply. Don't press the plate down or spread it by rubbing, just dab and pull in succession. You should get all the glue off like that. Else a suitable gentle solvent like paraffin or white spirit should dissolve the glue, wipe with a clean rag.
#6 Re: Number plate reclaimed
Posted: Tue Mar 15, 2022 9:21 pm
by KevinJ
Thanks all done, somehow looks better with the original plate ;-)
#7 Re: Number plate reclaimed
Posted: Wed Mar 16, 2022 12:21 am
by DWW
Looks perfect 8-)
#8 Re: Number plate reclaimed
Posted: Wed Mar 16, 2022 11:52 am
by paydase
Nice on a black body as you only see the white letters!
