#1 Recover Facia Panels?
Posted: Tue Mar 15, 2022 12:57 am
by mxke
The covers on the speedo/tach facia and the glovebox facia have come loose.
Do I try to reglue or replace the vinyl covering?
If replace, where does one locate a suitable material?
Thanks in advance.
Mike
#2 Re: Recover Facia Panels?
Posted: Tue Mar 15, 2022 1:46 am
by bitsobrits
I re-glued mine with good success. I completely (and carefully) peeled off the original material and cleaned both the vinyl and and metal pieces before using 3M 77 spray adhesive.
#3 Re: Recover Facia Panels?
Posted: Tue Mar 15, 2022 5:23 am
The material covering the consoles is a thin plastic that is NLA.
If you can reglue what you have it is preferable to recovering it in vinyl which is much thicker.
#4 Re: Recover Facia Panels?
Posted: Tue Mar 15, 2022 12:34 pm
by lowact
Yep. Had mine recovered in vinyl,the thickness is an issue with the glove box lid.
#5 Re: Recover Facia Panels?
Posted: Tue Mar 15, 2022 7:06 pm
by JerryL770
After you have re-glued the covering give it a wipe over, with of all things!! WD40
Comes up very nicely on mine.
