The car has been with Hutsons since January after a trailered trip north that was uneventful, save discovering two would-be emigrants hiding under the tarp as we boarded the ferry at Ouistreham.
Nice try, lads.
The shell had zero rust, but a late eighties restoration had left all sorts of unsatisfactory legacies, and having decided that these were beyond my local skill-sets it has been a pleasure to see the scuttle re-skinned (Andy Rayner at Hutsons admired Chuck's Monocoque panels) and the sills removed to put nicer ones, this time in the right place.
Angus Moss points out that his car is LHD as he "can only ever really use it properly in France", and I think I've decided to swap mine to LHD ........... which it was originally anyway when it went to the US in 1962.
I'm guessing (hoping !) that there is an embarassment of unused LHD kit lying around in the UK, and I'll put an advert on the Forum to that end.
Aside from the general, I did have a couple of more specific questions that The Usuals will be able to answer from the tips of their tongues.
1. Are the LHD and RHD harnesses massively different ?
As my harness has already been modified to cope with my numerous alterations, I'm inclined to want to keep it - save for stripping off all the binding, tweaking whatever needs doing for the RHD-LHD swap, and then getting Autosparks to re-bind it.
Is that a realistic approach ?
2. If I wanted to make my own cable-operated throttle, what is the best starting point to get a drop-down LHD throttle pedal set-up as a basis for such an adventure ? I can't (yet) justify £750 on the Mangoletsi one and think I have enough cable-operated experience to make this a plausible avenue to explore "solo" as it were.
Nice to be back.
