The Yoof! Efi Conversion. These Guys will Go Far.
Topic author - Posts: 1388
#1 The Yoof! Efi Conversion. These Guys will Go Far.
#2 Re: The Yoof! Efi Conversion. These Guys will Go Far.
I asked them what throttle bodies they used and they said triple SUs!
Angus 67 FHC 1E33656
61 OTS 875047
61 OTS 875047
#3 Re: The Yoof! Efi Conversion. These Guys will Go Far.
I have a Triumph TR3 running on Jenvey Heritage throttle bodies which resemble a Weber body.
https://store.jenvey.co.uk/throttle-bod ... itage-dcoe
Jenvey were considering producing their conversion with look a like SU bodies but as far as I'm aware haven't progressed that yet. These guys seem to have taken that route.
The TR with some head, cam and exhaust work together with 89mm diameter liner conversion, up from 86mm, showed 137.5 bhp on the rolling road. Drivability is amazing compared with the standard set-up.
Tim
1965 S1 fhc
1965 S1 fhc
#4 Re: The Yoof! Efi Conversion. These Guys will Go Far.
Personally I love my 3 SU's, in my opinion they are an important component in dictating the characteristics of the XK motor in its fueling, when set correctly, and the way the e-type drives and behaves on the road. A perfect syncro'ed five speed box or a modified diff could probably be the only other changes/improvements to the driving experience if so desired.
#5 Re: The Yoof! Efi Conversion. These Guys will Go Far.
I don’t know what happened to the project but Burlen had a test car(Mk 2 IIRC) with SU bodies hiding a fuel injection setup.
#6 Re: The Yoof! Efi Conversion. These Guys will Go Far.
My guess is that they have simply drilled injectors into the manifold from underneath. Its nice to use what you already own.
The SU pistons/needles, float chambers etc have just been disabled so it still looks nice externally.
A throttle position sensor has been attached to the end throttle spindle.
Why not?
I guess if you were going to reverse it, you would just plug up the injector holes at the same time you rebuilt the carbs with a new kit.
3 pairs of 45mm Jenvey throttle bodies are about £1200 the, last time I looked and a Rob Beere, Weber/Mangoletsi suitable manifold around £1,000. So you have already saved quite alot anyway. A set of new Weber lookalike Heritage Throttle Bodies is around £3,500. This might be even better looks wise to many.
The ITG cone filter they are using is around £80 and is very good. I guess the alterations to the air box mean you would need a new air box should you wish to go back to carbs.
Blanking off the distributor costs nothing.
You just need a trigger wheel, £35, 6 injectors from something like a Mini Cooper S, a fuel rail, 50psi Fuel line and regulator, a high pressure fuel pump, ECU and generic 6 cylinder loom. Emerald can supply that lot it is what all cars have been using for the last 20 years, so its pretty cheap and reliable.
So you would still be looking at around £2,500 worth of to finish the job off, that would mainly be the ECU cost I would think.
Well worth getting the final assembly set up on a proper rolling road, so thats another £400+.
Why not?
#7 Re: The Yoof! Efi Conversion. These Guys will Go Far.
It sounds like an SU copy of what Rick Patton did with Strombergs about fifteen years ago. You should be able to find this on the web if you cross reference him, Stromberg and Triumph. He CNC machined a plate to sandwich into the carburettor and mounted an injector into it.
Aside from the downside of spraying fuel a long way from where it needs to be, it is a neat way of making something appear to be "stock", until you look more closely, that is.
