Found a treasure
#1 Found a treasure
Decided to put some order with all the original stuff I got when bought the car, found an original service manual, original parts manual and an early Haynes manual also among that lot I came across this original horn push, regretfully seen better days .
#2 Re: Found a treasure
Good find. The horn push is very restorable - I did mine and it looks really good. Even if the Bakelite looks faded, you can bring it back to life using India ink and careful polishing. Even cracks and chips can be sorted out.
#3 Re: Found a treasure
Thanks Richard. will do in time....
#4 Re: Found a treasure
That horn push is a treasure, don't loose it or dispose of it. Reproductions don't look right, wrong colour gold.
Randall Botha
'64 3.8 fhc & '51 Mk 7
#5 Re: Found a treasure
Easy to spot the difference!
Growler ears should be in black squares, white squares should not be clipped.
S1 OTS OSB; S1 FHC ODB
#6 Re: Found a treasure
The only problem is that the underside ridge on the black surround is missing, I may have to ‘borrow that from the after market one if at all possible?
The new one I have
The new one I have
#7 Re: Found a treasure
The parts are interchangeable.
#8 Re: Found a treasure
Final result
It was quite difficult since the copper/brass plate was also missing from the original one so I had to perform a transplant but at the end it all worked well.
#9 Re: Found a treasure
Ears on the black squares - just as The Good Lord intended!
1969 S2 FHC - 1R20258
#10 Re: Found a treasure
#11 Re: Found a treasure
Perfect, just the right amount of patina.
Randall Botha
#12 Re: Found a treasure
#13 Re: Found a treasure
Too many E types
XK120 SUs
Too many E types
XK120 SUs
#14 Re: Found a treasure
Available on fleabay at £350+
#16 Re: Found a treasure
There should be a law against fitting an original growler on that steering wheel!
