windscreen wipers rest position
#1 windscreen wipers rest position
I see in photos of the triple wiper cars a variety of rest positions. Which is correct, should they be parked as low as possible to the frame, slightly resting on the frame or left floating resting on the glass itself? The problem predominantly concerns the end wiper which sort of tends to exceed the frame onto the scuttle.
#2 Re: windscreen wipers rest position
1965 S1 4.2 FHC (early)
#3 Re: windscreen wipers rest position
Thanks for replying, nor am I, will give it another try hope one notch will do it.....
#4 Re: windscreen wipers rest position
Can't you adjust the rest position using the knurled knob on the bulkhead. The service manual shows you how to do it.
You may need to do this in conjunction with moving the arms on the wheelbox splines.
'78 Land Rover Series 3 109
#5 Re: windscreen wipers rest position
Thanks,will have a look in the service manual...
#6 Re: windscreen wipers rest position
I find any make of cars with wipers way too high up the windscreen just don’t look right.
Here are mine :-
Here are mine :-
Dave Rose
1967 Series 1 4.2 FHC
#7 Re: windscreen wipers rest position
#8 Re: windscreen wipers rest position
Seems the factory tells us just how they should be positioned - low on the glass, parallel to the lower edge:
1965 S1 4.2 OTS 1E10425
#9 Re: windscreen wipers rest position
Very difficult to get the driver side one to look right, I don't like the position over the bottom trim. I straightened the kink in the arm a bit, looks & lies better.
Randall Botha
'64 3.8 fhc & '51 Mk 7
#10 Re: windscreen wipers rest position
That's such a good picture. I'd seen the black and white one previously but amazing to see it in colour. For the cars closest to the camera, it's really interesting to see the exterior/trim colour combinations
1964 S1 3.8 OTS
1964 S1 3.8 OTS
