#1 windscreen wipers rest position
Posted: Sat Nov 26, 2022 3:23 pm
by DWW
I see in photos of the triple wiper cars a variety of rest positions. Which is correct, should they be parked as low as possible to the frame, slightly resting on the frame or left floating resting on the glass itself? The problem predominantly concerns the end wiper which sort of tends to exceed the frame onto the scuttle.
#2 Re: windscreen wipers rest position
Posted: Mon Nov 28, 2022 8:17 pm
by caveman
Here’s mine Danny, I’m not a fan of arms/blades too high up.
#3 Re: windscreen wipers rest position
Posted: Mon Nov 28, 2022 10:48 pm
by DWW
Thanks for replying, nor am I, will give it another try :bigrin: hope one notch will do it.....
#4 Re: windscreen wipers rest position
Posted: Mon Nov 28, 2022 11:08 pm
by Series1 Stu
Can't you adjust the rest position using the knurled knob on the bulkhead. The service manual shows you how to do it.
You may need to do this in conjunction with moving the arms on the wheelbox splines.
#5 Re: windscreen wipers rest position
Posted: Mon Nov 28, 2022 11:22 pm
by DWW
Thanks,will have a look in the service manual...
#6 Re: windscreen wipers rest position
Posted: Tue Nov 29, 2022 9:18 am
by 44DHR
I find any make of cars with wipers way too high up the windscreen just don’t look right.
Here are mine :-
#7 Re: windscreen wipers rest position
Posted: Tue Nov 29, 2022 4:41 pm
by DWW
#8 Re: windscreen wipers rest position
Posted: Mon Dec 05, 2022 5:24 am
by JCrosby
Seems the factory tells us just how they should be positioned - low on the glass, parallel to the lower edge:
#9 Re: windscreen wipers rest position
Posted: Mon Dec 05, 2022 6:08 am
by Allrand
Very difficult to get the driver side one to look right, I don't like the position over the bottom trim. I straightened the kink in the arm a bit, looks & lies better.
#10 Re: windscreen wipers rest position
Posted: Fri Dec 09, 2022 12:08 pm
by Philk
JCrosby wrote: ↑
That's such a good picture. I'd seen the black and white one previously but amazing to see it in colour. For the cars closest to the camera, it's really interesting to see the exterior/trim colour combinations
