windscreen wipers rest position
#1 windscreen wipers rest position
Post by DWW » Sat Nov 26, 2022 3:23 pm
I see in photos of the triple wiper cars a variety of rest positions. Which is correct, should they be parked as low as possible to the frame, slightly resting on the frame or left floating resting on the glass itself? The problem predominantly concerns the end wiper which sort of tends to exceed the frame onto the scuttle.
caveman
#2 Re: windscreen wipers rest position
Post by caveman » Mon Nov 28, 2022 8:17 pm
Here’s mine Danny, I’m not a fan of arms/blades too high up.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
#3 Re: windscreen wipers rest position
Post by DWW » Mon Nov 28, 2022 10:48 pm
Thanks for replying, nor am I, will give it another try :bigrin: hope one notch will do it.....
#4 Re: windscreen wipers rest position
Post by Series1 Stu » Mon Nov 28, 2022 11:08 pm
Can't you adjust the rest position using the knurled knob on the bulkhead. The service manual shows you how to do it.
You may need to do this in conjunction with moving the arms on the wheelbox splines.
#5 Re: windscreen wipers rest position
Post by DWW » Mon Nov 28, 2022 11:22 pm
Thanks,will have a look in the service manual...
44DHR
#6 Re: windscreen wipers rest position
Post by 44DHR » Tue Nov 29, 2022 9:18 am
I find any make of cars with wipers way too high up the windscreen just don’t look right.
Here are mine :-
Dave Rose
1967 Series 1 4.2 FHC
#7 Re: windscreen wipers rest position
Post by DWW » Tue Nov 29, 2022 4:41 pm
JCrosby
#8 Re: windscreen wipers rest position
Post by JCrosby » Mon Dec 05, 2022 5:24 am
Seems the factory tells us just how they should be positioned - low on the glass, parallel to the lower edge:
1965 S1 4.2 OTS 1E10425
Allrand
#9 Re: windscreen wipers rest position
Post by Allrand » Mon Dec 05, 2022 6:08 am
Very difficult to get the driver side one to look right, I don't like the position over the bottom trim. I straightened the kink in the arm a bit, looks & lies better.
Randall Botha
Philk
#10 Re: windscreen wipers rest position
Post by Philk » Fri Dec 09, 2022 12:08 pm
That's such a good picture. I'd seen the black and white one previously but amazing to see it in colour. For the cars closest to the camera, it's really interesting to see the exterior/trim colour combinations
1964 S1 3.8 OTS
