#1 Clutch fluid black !
Posted: Fri Apr 07, 2023 10:36 am
So whilst carrying out some other work i noticed that my clutch slave looked decidedly moist.
Removed the cylinder and it was indeed beyond its best days. I replaced the master some time ago when converting from LHD to RHD.
I thought that I may as well change the flexible hose as this was likely the same vintage.
New cylinder bought and I also purchased one of those fancy remote bleed kits that allows you to move the bleed nipple to the top of cylinder and fit a short hose with a bracket fixed to the cylinder.
So with the system drained I was not really surprised to find the old fluid black and manky.
New cylinder and hose fitted without too much hassle despite limited room. Gave up with the remote bleed kit as the space to fit the banjo union is simply too tight. Maybe ok if you have the engine and box out.
Now the interesting bit.
Filled with new fluid and bled though. The new fluid also came out black ! Remember this is a newish master cylinder with new hose and slave. I used best part of of a litre of fluid until it turned clear. The fluid kim the reservoir has always been clear which to my mind means that the master cylinder must have been contaminating the new fluid.
Seemed very strange to me !
