Fosseway door mirrors
#1 Fosseway door mirrors
Post by DWW » Tue May 14, 2024 4:53 pm
I been using those clip-on to window frame mirrors for a while and found despite them being reasonable quality mirrors, the quality of the fitting to be lacking. The bracket where the two 5mm screws thread into are made of cheese and any attempt to tighten them results in a stripped threads. On the way back from a recent meet I discovered the driver side mirror was getting loose and on attempting to tighten it the thread gave up on me. Rather than go buy a new pair of the same I purchased from Amazon a cheap (around £7) an M5 heli coil kit which was an easy and now relay able fix.
#2 Re: Fosseway door mirrors
Post by malcolm » Wed May 15, 2024 8:27 am
I agree, not particularly well made. I put a bit of non-slip rubber in the fitting to help it grip.
AshM
#3 Re: Fosseway door mirrors
Post by AshM » Wed May 15, 2024 10:37 am
Had the same problem and agree with rubber insert.
I also replaced cross headed screws with SS counter sunk allen bolts. Neater and easier to tighten with more control using an Allen Key.
Series 2 FHC 1970
1R 20607
caveman
#4 Re: Fosseway door mirrors
Post by caveman » Wed May 15, 2024 5:05 pm
Bicycle inner tube works a dream.
1965 S1 4.2 FHC (early)
:wavegreatbritain:
mxke
#5 Re: Fosseway door mirrors
Post by mxke » Wed May 15, 2024 8:07 pm
I silversoldered two narrow nuts onto the back of the mount as one of the treaded holes had stripped.
#6 Re: Fosseway door mirrors
Post by DWW » Wed May 15, 2024 8:31 pm
Also not a bad idea :bigrin:
