#1 Alternate spark plug caps
Posted: Tue Jun 20, 2023 11:03 am
by Monkeyfinger
I am carrying out a slight upgrade/refresh of my leads and plug caps. I was planning to use NGK caps, as I have in the past, but apparently NGK have discontinued all of their 'classic' style of plug caps.
Just wondering what others would recommend? I currently have Champion original style caps that I must have put on 25 years ago, but I just wanted something with better sealing and a tighter fit, if such a thing exists
#2 Re: Alternate spark plug caps
Posted: Tue Jun 20, 2023 2:32 pm
by malcolm
I suppose my thought would be that if they've worked ok for 25 years, must be ok?
#3 Re: Alternate spark plug caps
Posted: Tue Jun 20, 2023 4:07 pm
by Monkeyfinger
I'm not totally disputing that, Malcolm, but I did cure a slight misfire by just pulling the caps off/on the plugs last week. Also, it's my car, and I fancy a small aesthetic ignition mod, so I'd appreciate recommendations.
#4 Re: Alternate spark plug caps
Posted: Tue Jun 20, 2023 4:32 pm
by DWW
#5 Re: Alternate spark plug caps
Posted: Tue Jun 20, 2023 6:02 pm
by malcolm
It wasn’t a criticism Richard. I thought from your post that you were worried about the fit and sealing qualities of your caps so was trying to reassure you.
#6 Re: Alternate spark plug caps
Posted: Wed Jun 21, 2023 9:12 am
by Monkeyfinger
Understood Malcolm, no problem. I'm actually looking to fit a cam cover mounted lead separator, matched with new leads and caps. I can then keep the 'original' set as a travelling spare and maybe have a little more reliability from a nice new setup. I'm just tinkering really, and I do more of that than driving at the moment...
#7 Re: Alternate spark plug caps
Posted: Wed Jun 21, 2023 3:51 pm
by MSM
I use a set of Magnecor plug leads, the plug caps provide a very positive fit and they are well sealed although I don't understand why you want good sealing. The Champion 'bow-tie' plug caps provide no sealing at all unless you add a skirt to them.
#8 Re: Alternate spark plug caps
Posted: Thu Jun 22, 2023 9:59 am
by Monkeyfinger
Thanks - I'll look at these. All I want to know, is alternatives that people have used, bearing in mind that NGK don't seem to be an option any longer.
#9 Re: Alternate spark plug caps
Posted: Wed Jun 28, 2023 2:39 pm
by Andyp_67E
I used this company
https://www.gsparkplug.com/ignition/spark-plug-caps
Very knowledgeable on the current options
#10 Re: Alternate spark plug caps
Posted: Sat Jul 01, 2023 11:39 pm
by mtnjag
They do appear to be available, depending on type wanted, on Amazon, Ebay, and other suppliers that still have stock.
I assume for a limited time.
#11 Re: Alternate spark plug caps
Posted: Sun Jul 02, 2023 10:29 am
I use these Champion WC 548 reproductions with BPR resistor plugs.
https://steadfastcycles.com/collections ... ch-triumph
Simple, reliable and as fitted to all E-Type's up to mid 1964 but appropriate for all. The letters can be highlighted with some white paint to impress!
This bulletin shows them in profile - UK cars had to be fitted with suppressors by law in 1964:
#12 Re: Alternate spark plug caps
Posted: Tue Jul 04, 2023 8:24 am
by Monkeyfinger
Well, after ordering 1 set from Ebay, which turned out not to be available, I have another set of NGK caps on order - I'm still waiting for these, but remain hopeful.
