#1 Connecting a trickle charger
Posted: Sun Nov 26, 2023 7:42 pm
by Mart
After 18 years of ownership I discover what I think is an Optimate SAE71 style charger lead curled up behind the binnacles. It would surely be much easy to keep the battery topped up in winter without having to angle the hood open!
But I'm struggling to find how to connect it to my CTEK XS800 trickler. Ths has what I think is called a "comfort connector"
I've attempted to attach photos of each attachment.
My preferences are buy an adaptor gold , buy a different charger silver and mess unmecessarily with anything in the car a very distant bronze.
I can't find a suitable adaptor on the web. So what do you wiser people recommend?
#2 Re: Connecting a trickle charger
Posted: Sun Nov 26, 2023 7:53 pm
Befor I plugged a charger into it I'd make sure its connected to the battery...strange place to have a charge socket as you then need to have the charger lead running through the door?
#3 Re: Connecting a trickle charger
Posted: Sun Nov 26, 2023 9:49 pm
by Robbiee
I have a CTec leads permanently attached to the battery terminals
When I plug the ctec in the lead comes forward over the soft rubber strip into the front wheel well
#4 Re: Connecting a trickle charger
Posted: Mon Nov 27, 2023 5:59 pm
by Mart
mgcjag wrote: ↑Sun Nov 26, 2023 7:53 pm
It's a soft top, so either top off or windows open. I will check as you recommend. Any thought on what adaptor i need, assuming that it is indeed connected?
#5 Re: Connecting a trickle charger
Posted: Mon Nov 27, 2023 6:46 pm
Your photos show 2 different plugs...doubt you can find an adaptor that fits both...but who knows..I would rewire a socket by the dash to fit your ctek plug....Steve
#6 Re: Connecting a trickle charger
Posted: Mon Nov 27, 2023 7:39 pm
by edriver
Hi Mart,
the vehicle side connector seems not to be an SAE 71 style connector. If it would be one, then Ctek sells the interface Artikelnr. 56-564. The best pictures are on Amazon
https://www.amazon.de/CTEK-Anschlusslit ... 2233290675
It comes with a battery charge indicator. Maybe that you find a match for SAE71 to what you have found in the dash.
Klaus
#7 Re: Connecting a trickle charger
Posted: Tue Nov 28, 2023 9:08 am
by malcolm
I just crocodile clip onto the battery. Doesn't take a tick to open the bonnet.
#8 Re: Connecting a trickle charger
Posted: Tue Nov 28, 2023 8:40 pm
by david.coan
My trickle charger goes into my cigarette lighter,ctek charger and buy the adaptor
https://www.ctek.com/uk/battery-charger ... t-cig-plug
So easy to remove before a drive and re instate when i park her back in the garage.
#9 Re: Connecting a trickle charger
Posted: Tue Nov 28, 2023 9:11 pm
by caveman
If you’ve got a tow bar
, here’s another CTEK option;
https://thomasperformance.co.uk/brands/ ... le-charger
