It turns out to need quite a bit doing to ensure reliability on a maybe 2,000 mile journey.
Clutch slave and master cylinders are leaking, coolant hoses are cracking and swelling but most important (?), I've been mithering for some time about the clunk I get from the rear end at times. The differential needs a rebuild. There's play in one output shaft bearing and also possibly play in the spider gear shaft. I've contacted Simply Performance for a rebuild cost. Awaiting the costly news!
Whilst the IRS is out I'll have remote bleed kit fitted. Onwards
