Testing an AI programme on E Types
Tony
#1 Testing an AI programme on E Types
Post by Tony » Sun Mar 30, 2025 9:11 am
Question : Step by step procedure for replacing the rear crank shaft oil seal on a 1962 Series 1 E Type Jaguar roadster.
Two second answer by AI programme. Have not checked how good it is so feel free to rip it apart or praise from your experience.
Replacing the crankshaft rear oil seal on a 1962 Series 1 E-Type Jaguar roadster requires careful planning and execution. Here's a step-by-step guide to help you through the process:
## Preparation
1. *Gather necessary tools and parts*:
- New crankshaft rear oil seal
- Gasket sealant
- Oil seal installation tool (optional)
- Socket set
- Torque wrench
- Rear main bearing cap gasket (if leaking)
2. *Jack up the car and support it*:
- Raise the front of the car using a hydraulic jack
- Support the car with axle stands for safety
3. *Remove the engine undercover and transmission tunnel cover*:
- Take out the screws holding the engine undercover and transmission tunnel cover
- Remove the covers to access the rear of the engine
## Step 1: Remove the Transmission
1. *Disconnect the transmission linkage*:
- Remove the nuts holding the transmission linkage to the transmission
2. *Remove the transmission mounts*:
- Take out the bolts holding the transmission mounts to the chassis
3. *Pull the transmission back*:
- Gently pull the transmission back, taking care not to damage the input shaft or clutch
## Step 2: Remove the Flywheel and Clutch
1. *Remove the flywheel bolts*:
- Use a socket wrench to remove the bolts holding the flywheel to the crankshaft
2. *Pull the flywheel off*:
- Gently pull the flywheel off, taking care not to damage the crankshaft or flywheel
3. *Remove the clutch assembly*:
- Take out the bolts holding the clutch assembly to the flywheel
## Step 3: Remove the Rear Main Bearing Cap
1. *Remove the bolts*:
- Use a socket wrench to remove the bolts holding the rear main bearing cap
2. *Pull the cap off*:
- Gently pull the cap off, taking care not to damage the bearing or cap
## Step 4: Remove the Old Oil Seal
1. *Locate the oil seal*:
- Find the crankshaft rear oil seal, usually located behind the rear main bearing cap
2. *Remove the seal*:
- Use a seal removal tool or a screwdriver to carefully pry out the old seal
## Step 5: Inspect and Clean the Area
1. *Inspect for damage*:
- Check the crankshaft, rear main bearing cap, and surrounding area for any damage or wear
2. *Clean the area*:
- Use a wire brush and solvent to clean the area around the oil seal
## Step 6: Install the New Oil Seal
1. *Apply sealant*:
- Apply a thin layer of gasket sealant to the new oil seal
2. *Install the seal*:
- Use an oil seal installation tool (if available) or a blunt instrument to carefully press the new seal into place
## Step 7: Reassemble the Rear Main Bearing Cap
1. *Replace the rear main bearing cap*:
- Put the cap back in place, ensuring it's properly aligned
2. *Replace the bolts*:
- Tighten the bolts in a star pattern to avoid damaging the gasket
3. *Tighten the bolts*:
- Use a torque wrench to tighten the bolts to the specified torque
## Step 8: Reassemble the Flywheel and Clutch
1. *Replace the clutch assembly*:
- Put the clutch assembly back in place, ensuring it's properly aligned
2. *Replace the flywheel*:
- Put the flywheel back in place, ensuring it's properly aligned
3. *Replace the flywheel bolts*:
4. *Tighten the bolts*:
## Step 9: Reassemble the Transmission
1. *Push the transmission back*:
- Gently push the transmission back into place, ensuring it's properly aligned
2. *Replace the transmission mounts*:
- Put the transmission mounts back in place, ensuring they're properly aligned
3. *Replace the transmission linkage*:
- Put the transmission linkage back in place, ensuring it's properly aligned
## Step 10: Replace the Engine Undercover and Transmission Tunnel Cover
1. *Replace the engine undercover*:
- Put the engine undercover back in place, ensuring it's properly aligned
2. *Replace the transmission tunnel cover*:
- Put the transmission tunnel cover back in place, ensuring it's properly aligned
## Step 11: Lower the Car and Test
1. *Lower the car*:
- Carefully lower the car to the ground using the hydraulic jack
2. **Test the
Tony (E typed)
Tony
#2 Re: Testing an AI programme on E Types
Post by mgcjag » Sun Mar 30, 2025 9:26 am
Hi Tony....its a load of nonsense....what's the issue..do you have a leaky rear and looking for help on how to fix it...best procedure is read the service manual then search the forum and ask questions here.....Steve
Tony
#3 Re: Testing an AI programme on E Types
Post by Tony » Sun Mar 30, 2025 10:31 am
Hi Steve, it was more just an interesting exercise on the power of AI.
The answer to my oil leak is for me to get of my backside and fix it or pay up to have it done.
We have to test out these new systems to see if they have any value. I always thought you were a computer until I met you. Glad to say the reality was far more satisfactory.😀😂
Hope to see you around some time
Tony
Tony (E typed)
Tony
angelw
#4 Re: Testing an AI programme on E Types
Post by angelw » Sun Mar 30, 2025 1:16 pm
Hello Tony,
I didn't read past Step 1; that was enough balderdash for one day. There's a Right way, a Wrong way and the AI way of going about this job. The AI way is the same as the Wrong way, the only difference is that problem appear quicker with the AI method.
Some say it's possible to remove the Gearbox without removing the engine. It may be, with great difficulty, but a saying springs to mind I used with some of my clients that I was close enough to to be able to insult them without retribution, when they wanted to short cut a procedure; "Never enough time to do the job right, but always enough time to do it again".
As Steve suggested, read the workshop manual to get the procedure.
