#1 Metalastik 17/903 4 steering rack mount
Posted: Fri May 08, 2026 8:10 pm
by Simon2824
Looking to replace the original mounts on my E type series 3 experimental model -EX102. Usual series 3 mounts are not direct replacement neither are series 2. The single shaft on the rear is short (about 1”) and the 3 holes are inline. I understand they were fitted to series 1. Does anyone have new olds stock or no supplier as I would like to keep as original as possible.
Many thanks
#2 Re: Metalastik 17/903 4 steering rack mount
Posted: Sat May 09, 2026 7:10 am
by Gfhug
Simon, can’t help you there, but please do tell us more about your car. It sounds interesting.
#3 Re: Metalastik 17/903 4 steering rack mount
Posted: Sat May 09, 2026 7:30 am
Hi Simon....I think these mounts were used on the very early S1 racks?......interesting ....there must be a solution as lots of early cars have been restored....if you cant find replacements then...could you modify S2/3 mounts to fit....or consider making solid mounts.....Steve...ps have flagged this to someone who may know...
#4 Re: Metalastik 17/903 4 steering rack mount
Posted: Sat May 09, 2026 2:12 pm
by Simon2824
The series 2 is similar in look but the size is different and has a longer thread. The 3 is correct dimensions but curved ends. Seems I’ll have to go for these unless I order 1200 from the manufacturer….
#5 Re: Metalastik 17/903 4 steering rack mount
Posted: Sat May 09, 2026 2:22 pm
by Simon2824
If you AI Jaguar experimental EX102 you will get quite detailed info. It is one of 4 produced, the only LHD, has series 3 suspension, cooling , brakes and bonnet. The scope on the front is smaller than the manufactured series 3. A lot of the metal work on the bulkhead is hand welded. Brake ducts similar. USA rear prop ratio. Did have emissions fitted. All paper work from 1976.
#6 Re: Metalastik 17/903 4 steering rack mount
Posted: Sat May 09, 2026 2:30 pm
The guy I flagged it to is investigating....hold fire for a while....Steve
#7 Re: Metalastik 17/903 4 steering rack mount
Posted: Sun May 10, 2026 11:12 am
by Simon2824
Thank you I await in hope
#8 Re: Metalastik 17/903 4 steering rack mount
Posted: Mon May 11, 2026 2:10 pm
by 1954Etype
I have checked 2 early cars (47 and 39) and they both have the 'normal' s1 mounts with the long studs. I see in the parts book the mount was changed early on in production but both of these cars were fitted with the first type so it looks like what you have is a hybrid mount of some type.
Might be best if you looked at other models?
Sorry I can't be of any more help.
#9 Re: Metalastik 17/903 4 steering rack mount
Posted: Mon May 11, 2026 2:15 pm
Hi Simon.....Angus is the expert I flagged it to.....so no joy there......thanks Angus.........
#10 Re: Metalastik 17/903 4 steering rack mount
Posted: Mon May 11, 2026 7:56 pm
by Simon2824
Thank you mgcjag and to Angus for your time on my behalf. I have been doing research and so far cannot find anyone who recognises it all I have found is a mention of the shorter stud on the series 1 to not catch! But not saying what.
