Bio Fuel and consequences for our cars?
SESH
#1 Bio Fuel and consequences for our cars?
Post by SESH » Tue Dec 20, 2011 2:21 pm
Just read this article on Pistonheads, and wondered what views everyone had about the future effects of it on our cars and any mods that we will need to carry out.
Owners of some older PH favourites will need to be on the look-out for changes at petrol pumps next year as fuels with a greater mix of bio renewables will start to become available which could harm older engines.
Under current legislation petrol can contain up to five per cent biofuel without the pump having to mention the percentage or warn the driver. This is because the mix is so low it's not thought to have a detrimental effect on the engine. Legislation is currently in place to guarantee the mix will be five per cent by April 2013 and almost all fuel already contains a small bio element.
Over the five per cent level and the pump must, by law, be labelled "Not suitable for all vehicles: consult vehicle manufacturer before use."
However, due to Europe's Renewable Energy Directive (RED) higher percentages of biofuel are on their way to the UK. RED requires members of the European Union to ensure that 10 per cent of energy used in road transport is from a renewable source by 2020. Interestingly, to reach a 10 per cent renewable energy figure, a 15 per cent mix of biofuel is required.
While this deadline is some way off, fuel companies are planning to introduce petrol with a 10 per cent bio-mix, known as E10, to the UK next year. BP is expected to be one of the first to offer the higher percentage biofuel.
To marry-up with the changes, the Department for Transport is currently considering downgrading the wording on biofuels so that only that with a greater than 10 per cent mix will have to be labelled with the words "This fuel contains more than 10 per cent biofuel."
A BP insider has likened the change to what happened when we swapped from leaded fuel to unleaded. And the reason only newer cars can run on E10 is because the higher ethanol content from has a corrosive effect on the seals and some alloy components in the fuel system. Modern engines have been built to withstand this.
While many brands, BMW among them, have declared their entire petrol engine ranges fine for E10 there are some exceptions, including 993 (and earlier) Porsche 911s. First generation FSI engines used in VW, Audi, SEAT and Skodas typically between 2000 and 2006 are not E10 compatible but all the group's current petrol engines are.
Other PH favourites like pre-2002 MX-5's and icons such as the Peugeot 205 GTI will also not be able to use the E10 fuel. Unlike the switch from leaded to unleaded petrol, there are (as yet) no fuel additives on offer to counter the issues around E10 either.
Drivers of older cars that won't take the E10 biofuel will have to seek out regular fuel, which is expected to become less common over time.
andy303
#2
Post by andy303 » Tue Dec 20, 2011 5:29 pm
E-10 fuels have been used in North America for some time now, and we are surviving, no worse for the wear. Mostly. Ethanol will attack rubber and some alloys if left to its own devices for long enough. The general consensus is that its OK to use as long as the car is driven frequently. If the car goes into storage then one of the commonly available fuel stabilizer additives should be used. I am sure that when E10 comes on the market in the UK that the additives will follow close behind.
I use it in my car, but I also add some of this stuff: http://tinyurl.com/3tlxof9
If you would like to read hours of often contradictory opinions and information about the subject, go to the jag-lovers site and use "ethanol" as a search term.
Heres one recent thread to get you started: http://forums.jag-lovers.org/av.php?1486276m18
Andy Blackley
Chardon, Ohio
69 S2 2+2 http://www.xkedata.com/cars/detail/?car=1R41606
Fear God and Dreadnought
