#1 Carb balancing in or near Newbury / reading
Posted: Fri Jul 06, 2012 8:01 pm
by Beastieboy
Hi, I need to find a decent garage with experience of balancing triple carbs, checking mixture etc
Recommendations welcome Please message me direct if you want to avoid advertising if that is an issue
Posted: Mon Jul 09, 2012 9:21 pm
by Woolfi
Checking mixture at iddle or speed ? This can be a big difference , IF the exhaust or the air-filter system has been changed.
A garage normally is measuring the mixture at idle. Are you driving with iddle ? No !
A needle profile of the carb-needles is fitting to the motor, if there have been no or only minor changes in the "motor-system".
Regards Wolfgang Gatza
Posted: Tue Jul 24, 2012 11:48 am
by snowdmc
Thomas Barclay at Gerrards Cross balanced my v12 and is an etype specialist, so should be able to help - only a short distance past reading, near uxbridge
