Wiper Rack Replacement
and.nox
#1 Wiper Rack Replacement
Post by and.nox » Tue Jun 18, 2013 2:38 am
Can anyone assist with this problem
On my S3 coupe, the knurled nuts to which each wiper arm is fixed are badly worn, to the point where one of them no longer actually drives the wipers across the screen. It just spins in the base of the wiper arm. Is there a way of replacing these knurled nuts in situ, rather than having to strip out the dash and everything behind it and replace the complete wiper rack mechanism?? :cry:
Andrew S
'73 S3 COUPE, '15 Ford XR6
chrisvine
Post by chrisvine » Tue Jun 18, 2013 1:23 pm
Andrew,
A recent post discussed a similar problem - http://etypeuk.com/forum/viewtopic.php?t=4163
Unless the splined end that you're referring to is no longer attached to the drive spindle (I think there's three small peened over protrusions that secure the splined part to the spindle), then you'll almost certainly need to look at replacing the rack and the removal of the dash top.
Chris
1969 S2 OTS, Elise S1
Dave K
Post by Dave K » Tue Jun 18, 2013 1:35 pm
Andrew,
I agree with Chris that the wiper rack will have to come out. However if you go to a scrapyard and get hold of a Jaguar rack you can remove the splined shafts and fit them to yours.
I bought parts of a rack from Stoneleigh a few years ago to repair mine. You need to peen the ends over so the rack has to be placed on a hard firm surface to allow you to peen the ens over.
and.nox
#4 wiper rack replacement
Post by and.nox » Tue Jun 18, 2013 11:05 pm
Thanks Dave and Chris. I figured as much. Oh well it has to be done so I'll start looking for a good second hand one. If not, it's back to Barretts.
Andrew S
phil.dobson@mac.com
#5 wiper rack
Post by phil.dobson@mac.com » Thu Jun 27, 2013 4:56 pm
Drill it and insert a roll pin
and.nox
Post by and.nox » Thu Jun 27, 2013 10:51 pm
Phil,
Please excuse my ignorance, but what's a roll pin?
Andrew S
Post by PeterCrespin » Fri Jun 28, 2013 11:34 am
and.nox
Post by and.nox » Sat Jun 29, 2013 9:37 am
Aah yes - I recognise those. Thanks Peter
Andrew S
