I know prices are rising but didn't realise things were this bad!
http://tinyurl.com/nuxxtek
Ebay clutch slave cylinder
Not too bad provided you need ten!
No Pete, that is 10 available at ?550 each not the other way around. "This part matches Original Equipment (OE) quality specifications ISO 9001 which means that it is at least as good if not better than the original part the manufacturer supplied the car with. These are not cheap copies which don't normally last long, save yourself the False Economy of replacing your parts more often than you should need to"
Original Jagua boxed versions available for ?55 here: http://tinyurl.com/q6dltyk
I bought one of the items Dave shows - they appear to be genuine original parts.
1964 FHC 4.2
Then buy a copy from the Usual Culprits, and spend ?50 to have it reconditioned with UK seals and a stainless sleeve. Better than new.
Five hundred and twenty three quid ? Gotta be ------------- joking.
