Ebay clutch slave cylinder
Dave K
#1 Ebay clutch slave cylinder
Post by Dave K » Wed Jan 08, 2014 5:27 pm
I know prices are rising but didn't realise things were this bad!
http://tinyurl.com/nuxxtek
Post by PeterCrespin » Wed Jan 08, 2014 11:14 pm
Not too bad provided you need ten!
Post by Heuer » Wed Jan 08, 2014 11:49 pm
No Pete, that is 10 available at ?550 each not the other way around. "This part matches Original Equipment (OE) quality specifications ISO 9001 which means that it is at least as good if not better than the original part the manufacturer supplied the car with. These are not cheap copies which don't normally last long, save yourself the False Economy of replacing your parts more often than you should need to" :roll:
Original Jagua boxed versions available for ?55 here: http://tinyurl.com/q6dltyk
ChrisC
Post by ChrisC » Thu Jan 09, 2014 12:14 pm
I bought one of the items Dave shows - they appear to be genuine original parts.
1964 FHC 4.2
rfs1957
Post by rfs1957 » Thu Jan 09, 2014 2:26 pm
Then buy a copy from the Usual Culprits, and spend ?50 to have it reconditioned with UK seals and a stainless sleeve. Better than new.
Five hundred and twenty three quid ? Gotta be ------------- joking.
