paint code for Gold paint engine block
#1 paint code for Gold paint engine block
Im restoring a 1966 e-type , can anyone tell me the color code or name of the color of gold on the block, any info would be much appreciated
I use plastikote gold paint. It is water based. easy to apply and lasts well
#3 Re: paint code for Gold paint engine block
Block was black. Assume you mean head?
Chris
Is that the metallic gold colour 620 in a spray can?
Ian
Ian
64 S1 4.2 OTS 1E10012 73 S3 2+2 manual 2013 V6 F type OTS
norman m. macleod
#5 Gold Paint Cylinder Head
Los Bravos 1966 Peter.........
would've thought a bit before your time.....! Anyway, I used POR15 Old Gold Engine paint on the cylinder head, comes up good, how accurate to original however, not too sure, but I'm not an originality slave. Heatproof, bullet proof, etc., only drawback it is eye-wateringly expensive.......
Best regards,
Norman.
Best regards,
Norman.
1967 S1 2+2
#6 Re: Gold Paint Cylinder Head
[Adopts Robert De Niro accent]:norman m. macleod wrote:Los Bravos 1966 Peter.........would've thought a bit before your time.....!
"You talkin' to me?"
60 this year Norman, 1966 was well within my time!
Ian : I don't know the number, but the plastikote I use comes as brush on in a small glass bottle . Available from model shops etc, costs 3 or 4 quid and will do 2 or 3 heads . One of the beauties of the brush on is that you can redo a head without removing the domed nuts, and it flows very easily
norman m. macleod
Hi again Peter,
Between 1966 and 1969 we had to play it (Black is Black....) as a request number, (our rock band in Zambia...) until the onset of mild nausea....Silver lining was its partial contribution to the purchase of my first E-Type (new...) in November 1969.....
70 last year, you may genuflect at the angle of your choice.....
Best regards,
Norman.
Best regards,
Norman.
1967 S1 2+2
Got it! Grey is grey, since you went away?
And grey brings us back to heads...
norman m. macleod
#10
Now that last line, Peter, is one of the best examples of homonymic paronomasia I have seen in some time....I am overcome with admiration :o Perhaps best draw a line there.....!
Best regards,
Norman.
Best regards,
Norman.
1967 S1 2+2
#11
Yeah, I'll quit while I'm a headnorman m. macleod wrote: Perhaps best draw a line there.....!
norman m. macleod
#12
I'd almost decided to surrender, Pete, but that last(unintended?) example of paraprosdokian syllepsis downed me......
Can I change the subject.....? In defence of my position as a dedicated 2-wheel fanatic (even some Triumphs, as you know.....) a pic of my home-built wide-line Manx-framed supercharged (Shorrock-2-litre) Vincent (1967). Can you believe it was street-registered....? Those were the days...... Don't have your e-mail address, though....
Getting somewhat tired of some of those "experts" on the Forum, been there and done all of that, student under Dr. Blair and Kaaden in the Sixties, I'll leave you with one of my favourite quotes.....
"Those people who think they know everything are a great annoyance to those of us who do...." Isaac Asimov.
nmm1943
nmm1943
1967 S1 2+2
Unfortunately Norman, Issac did not own an E-Type
There are no "experts" here just enthusiastic owners who are willing to share their, sometimes, patchy knowledge for the common good. Out of that comes a collective although possibly subjective consensus on what may, or may not, have happened during the gestation and life of the E-Type. If you want expert opinion you need to consult an expert e.g. Phillip Porter.
Back on topic the paint Jaguar used was Bradite 'Old Gold' metallic. The company still exists in Manchester but I have spoken to them and they no longer supply automotive paints nor do they have any NOS samples to hand. I used a gold engine paint I found on eBay and it was a good match to what was left of the original. The early cars used a paint termed 'Gold' by Jaguar which was a non metallic paint and has retrospectively been called 'Pumpkin' by the Americans who know what that vegetable is but a puzzlement to us Brits (we don't have Pumpkins - Turnips, yes). "Old Gold' is a shade of Orange that is 71% saturated and 81% bright. For reference purposes, Old Gold has the hex value #CFB53B."
If you go to our Forum KB there are some suggestions on 'Old Gold' alternatives but most of the Gold engine paints on eBay, brushable or spray, will be good enough for any concours judge or your own satisfaction.
david muir
#14
I used a 15ml. tin of Humbrol gold as used on Airfix kits.........plenty for a few coats and touch-ups and much cheapness!
1964 3.8 FHC
I used E-tech engine enamel available on eBay amongst others:
