Specifications:
Brand: FLOUREON?
Chemistry: Li-Polymer
Real Capacity: Real 13600mAh
Color: Green-Black
Product Input: DC 15V/1A (3.0*2.0mm)
Product Output: DC 12V 16V 19V / 2A 3.5A 3.5A; DC 5V 2A; 12V 200A (400A max) to start car
Peak current: 400A (3s)
Applicable temperature range: -10℃~60℃
Plug: UK
Dimension: 165x 79 x 40 mm
Box Size: about 250 x 200x 65 mm
Several versions available of 13600mAh or above : http://tinyurl.com/lekcpr3 They are so small I was wondering if it was worth carrying one when touring. They claim it will start the car 20 times on one charge and even with a dud battery/alternator/dynamo give you sufficient juice to get you approximately 20 miles to a garage or safety.
