Blanking plates
Malc
#1 Blanking plates
Post by Malc » Tue Dec 09, 2014 8:54 pm
There are two aluminium blanking plates above the passenger footwell which are located below the windscreen washer reservoir (on a RHD S1). I need to replace these but I can't find them in any catalogue (SNG, J37 or J38). Does anyone know the part number or where I may get them from?
Malc
Series 1 2+2, 1968 Blue exterior, grey interior
neil4444
Post by neil4444 » Wed Dec 10, 2014 7:23 am
Neil
1962 S1 OTS
1967 S1 FHC
Post by abowie » Wed Dec 10, 2014 8:21 am
Hutson's sell them.
neil4444
Post by neil4444 » Wed Dec 10, 2014 9:14 am
Malc,
The ebay link is the link to the Hutsons ones.
Neil
1962 S1 OTS
1967 S1 FHC
Malc
#5
Post by Malc » Wed Dec 10, 2014 11:23 am
Yup, they seem to be the ones - SNG said they were not available! Many thanks all.
Malc
Post by abowie » Wed Dec 10, 2014 8:39 pm
neil4444 wrote:Malc,
Doh!
Durango2k
Post by Durango2k » Wed Dec 10, 2014 8:54 pm
They are Steel, not alloy, at least in my S1 2+2
Carsten
Post by malcolm » Thu Dec 11, 2014 10:11 am
They are alloy in my series 2 2+2, so perhaps there was a crossover point for steel to alloy?
Post by abowie » Thu Dec 11, 2014 8:10 pm
The ones I got from Hutsons were steel. Annoyingly the studs fitted were metric, but at least they came with nuts.
Post by PeterCrespin » Fri Dec 12, 2014 2:48 pm
Jaguar parts were always pressed steel with spot-welded studs, right through to the end of Series 3.
The cad plate makes them look somewhat like aluminium I suppose. If anyone has alloy parts they are not factory AFAIK. Since they can be substituted with flat plate they are dead easy to mark out and make if someone in the car's past life wanted a bit of DIY 'bling'.
#11 Re: Blanking plates
Post by PeterCrespin » Fri Dec 12, 2014 3:05 pm
Malc wrote:I can't find them in any catalogue (SNG, J37 or J38). Does anyone know the part number or where I may get them from?
They are not shown in the pretty pictures but they are all listed at length in the Body Fittings section in J37/J38, spread over two pages down to the last nut and the plain and shake-proof washers for each nut.
Malc
#12
Post by Malc » Fri Dec 12, 2014 4:36 pm
Pete - found them, thanks. AAMOI, does your copy of J38 have any pretty pictures at all for 'Body Fittings'?
Malc
Malc
#13
Post by Malc » Fri Dec 12, 2014 4:47 pm
Having found the part numbers, it appears that SNG DO sell the parts after all (despite them telling me they didn't). It also seems that all the main suppliers do them incl David Manners and Hutsons (who incidentally are the cheapest). The part numbers are BD27413 & BD19713 (RHD), BD19712 & BD19711 (LHD), plus there is all sorts of gaskets, nuts & washers to go with!
Malc
paulsco
Post by paulsco » Fri Dec 12, 2014 5:31 pm
Hi Malc,
Be careful here; there are two different types of blanking plate. early cars had a narrower plate than the later cars over the pedal box.
The first Ebay link shows you the right shape, except this one does not have the bracket for the servo bottle.
BD19713 is the plate over the accelerator hole and it would be for a LHD car.
BD27413 is narrower and for the early car, pre 65.
paulsco
Post by paulsco » Fri Dec 12, 2014 5:48 pm
I should elaborate; I put those part numbers in the SNG site and looked at the pictures.
Post by PeterCrespin » Fri Dec 12, 2014 11:11 pm
Malc wrote:Pete - found them, thanks. AAMOI, does your copy of J38 have any pretty pictures at all for 'Body Fittings'?
My SNGB-purchased J38 has all diagrams cited in the spares listings under Body Fittings. As you can see from the text content, those are plates 49-53 inclusive.
Malc
#17
Post by Malc » Sat Dec 13, 2014 3:08 pm
Thanks Paul - I'll double check the parts before ordering them.
Malc
Malc
#18
Post by Malc » Sat Dec 13, 2014 3:27 pm
Thanks Pete - my copy of J38 has all the plates for all the sections - except for pates 49 - 53 in respect of the Body Fittings chapters! They are not even listed in the Index at the front, whereas all the others are.
If David Jones reads this, any chance of putting the parts catalogue for a 2+2 in the E-Type Knowledge Base (especially the diagrams/plates)?
Malc
Post by Heuer » Sat Dec 13, 2014 6:05 pm
If someone has digital copies to send me I will.
