http://www.ebay.com/itm/Other-Makes-Jag ... ars_Trucks
not sure if anyone else has seen this, think its the weirdest and most unusual take on an E-Type I have seen, wouldn't mind the Boss'9 motor for my Mustang though!
Spotted on ebay USA
Stuart Exelby
Good Lord! Surely this should go in the "No accounting for taste" section.....
1967 Series 1 OTS
Already there - has been for a few years.
That should be a capital offense.
Not just bad taste, but nearly undriveable as well! The Ford 427 is close on to 200 lbs heavier than the 3.8 Jaguar fitted.
The weight balance and handling are thrown completely out-of-whack!
It was quite popular in the 1970's and 80's in the US to drop a Big Block engine into an E-Type and see what it could do. The answer was often, "Not much" because too many things had to be changed to fit a V8 inside the frame rails.
1969 S2 LHD OTS
2013 VW Jetta TDi
Too many Diesel Tractors
2013 VW Jetta TDi
Moeregaard
I've seen a lot of V-8 conversion here on the west coast, but very few that I thought were done well. Most involved compromising the structural integrity of the subframe, by cutting and relocating the upper tubes to accommodate the wider girth of the V-8s. What got really annoying was when I showed my '65 at local events, I'd always get the one guy advising me to replace the 4.2 with a small-block Chevy while rattling off a laundry list of deficiencies supposedly endemic to E-Types.mike837go wrote:Not just bad taste, but nearly undriveable as well! The Ford 427 is close on to 200 lbs heavier than the 3.8 Jaguar fitted.
Mark (Moe) Shipley
Former owner '66FHC, #1E32208
Former owner '65FHC, #1E30036
PaulColeman
That's got to be worth the $100,000 asking price because it's got blue LEDs on the front of it :)
