New Reproduction Parts for E-Type's
#81 Re: New Reproduction Parts for E-Type's
Post by Heuer » Mon Aug 10, 2020 11:28 am
All the saloon's and the FHC used mirror #608 but the saloons had a different mounting foot. The new mirror should fit your original mount.
S1 OTS OSB; S1 FHC ODB
JulianBarratt
#82 Re: New Reproduction Parts for E-Type's
Post by JulianBarratt » Mon Aug 10, 2020 1:49 pm
David is correct - the mirror will fit to an original mouting foot. If you are struggling to fit, please do get in touch with us and we will be happy to advise.
MD at SNG Barratt Group
Herblay
Spain
#83 Re: New Reproduction Parts for E-Type's
Post by Herblay » Mon Aug 10, 2020 4:15 pm
Thank you Julian, I begin to suspect that my problem is the mounting foot, I’ll check as soon as I’m back of vacations and revert if needed. In case I need it, do you sell any reproductions of the original mounting foot?
S1 FHC 3.8
JulianBarratt
#84 Re: New Reproduction Parts for E-Type's
Post by JulianBarratt » Tue Aug 11, 2020 5:27 am
We do indeed offer the mounting:
https://www.sngbarratt.com/English/#/UK ... 0c20697%60
many thanks
#85 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Aug 19, 2020 11:54 am
Tim Goldthorp of Classic Quality (Parts) Ltd has been in touch with a new part many may be interested in:
"Quick email to say we have now manufactured a mechanical oil pressure gauge kit with the correct 0-60 gauge rather than the 0-100. The kit also comes complete with a union that replaces the electrical sender making it a very simple and straight forward kit to install. Please find a couple of pictures attached.
These retail at £125 plus vat and shipping but I can offer them to the forum members at a discounted price of £116 plus vat and shipping."
Mechanical oil pressure gauge kit
Correct Smiths 0-60 gauge rather than the 0-100 that is currently on the market
Suitable for Jaguar E-Type, Mk2, S-Type, 420
Kit comes complete with gauge, oil pipe, union and washers
The union supplied screws into the cylinder block filter head replacing the electric sender
This kit is a direct replacement to the original electrical oil gauge and sender unit which is notoriously unreliable and inaccurate
All parts are manufactured in the UK
https://www.classicquality.co.uk/
07912 439 982
tim@classicquality.co.uk
#86 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Aug 19, 2020 9:59 pm
To be clear the V shaped bezel is S1, rounded is S2. Easy to swap between them.
#87 Re: New Reproduction Parts for E-Type's
Post by Heuer » Thu Nov 05, 2020 11:29 am
Julian has been in touch to say they are now reproducing the FHC pivot bracket for the rear door prop; part BD28246 - made in polished stainless steel:
: https://www.sngbarratt.com/English/#/UK ... bd28246%60
#88 Re: New Reproduction Parts for E-Type's
Post by Heuer » Thu Dec 17, 2020 1:10 pm
Julian has brought Christmas forward and has released a range of premium reproduction parts:
C37217
A V12 product was remade by us in 2020 having previously been unavailable and is miles better in terms of casting quality than previous.
https://www.sngbarratt.com/English/#/UK ... 0c37217%60
C24686U
Camshaft sprocket for XK engines precision manufactured in the UK and the best quality version on the market. This was made in response to the other versions available as there was complaint that these were not high enough quality. This new one is more expensive than others on the market but we are always told that customers are prepared to pay a bit more to get something that works – so lets see.
https://www.sngbarratt.com/English/#/UK ... 0c24686%60
9750*
The handbrake fork again made from scratch in response to customer demand ref others on the market. We are confident that this is perfect match vs the original.
https://www.sngbarratt.com/English/#/UK ... %609750%60
8636
These aren’t a big seller but we have remade these in 2020 – the advantage of the ones we have made over previously available is these are an exact copy of the OE wiper rack, the wiper spindle operating arms being three different lengths and sweep correctly.
https://www.sngbarratt.com/English/#/UK ... %608636%60
C17872K*
Heater control knob. Again, not a big seller but we are really pleased with the finish that we have achieved on these – brand new tooling and an authentic feel to the part.
https://www.sngbarratt.com/English/#/UK ... 17872K*%60
C17912
In this case, I have a “before and after”. We remade this choke knob this year as the only ones available were quite poor in terms of finish and the writing was smudged – I have attached a photo of the previous. You can clearly see the difference on the new ones we have introduced:
New:
Old:
https://www.sngbarratt.com/English/#/UK ... f5fa812ecc
C18711
Heater Box Air duct for E-Type Series 1 & 2. Not the most exciting product but one that needed improving – which we did with new tooling this year and we now have good stocks:
https://www.sngbarratt.com/English/#/UK ... C18711*%60
C4405
A small but crucial part that we have remade this year. When we were trying to come up with some wording to market this (its not easy) – our man Pete came up with the following:
"Hidden deep inside the XK and XJ timing chest, this small but vital machined part has been historically abused by mechanics with improper tools and too little time. If the teeth are damaged or the body misshapen, it will not hold the upper timing chain tensioner steady during adjustment - leading to a poorly adjusted, noisy chain. So if a rebuild is in the offing, look carefully at this little piece of engineering and remember that a new made replacement is now available from SNG Barratt Group."
https://www.sngbarratt.com/English/#/UK ... 60c4405%60
#89 Re: New Reproduction Parts for E-Type's
Post by Heuer » Fri Feb 05, 2021 2:18 pm
Forum member Barrie (tinworm) has these for sale:
"I have for sale new reproduction S1.5/S2 ignition switch brackets .These fit on the steering column of the Federal S1.5 LHD and the early S2 when the cars had the column lock casting but the lock was not fitted. I only have 13 in this small run.
I also have made S1.5 RHD brackets - these were not as far as I know supplied by Jaguar as only the Federal cars had the collapsible column. With this bracket you can have the indicator switch on the correct side for RHD. I have only made two of these for now. All brackets are powder coated and are priced:
S1.5 £55 LHD and RHD
S2 £52 LHD and RHD
Plus post of course. No vat as I am not vat registered.
Please pm me if interested
Barrie"
Original thread: http://forum.etypeuk.com/viewtopic.php? ... 97#p140397
#90 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Mar 03, 2021 2:34 pm
Just received this from Forum member Grischa:
"As the E-Type under dash vents BD25733 / BD25734 are no langer availlable I went to a professional CAD engineering company who made a complete CAD data file of the part. This was sent to a professional 3D printing company and they produced brand new parts made of PA11 carbon material in perfect quality. Much better than scanned items. Connectors between the shaft and the operating cable are made of PA11, too, instead of metal. To manage costs there were some 20 pieces made.
So if anybody needs new vents for his E-Type or S-Type - here they are.
Price is € 120/pcs for the whole unit if buyer does selfassembling.
I can also provide the air diffusor bit only, as this part is spoiled at most cars, for €40/pcs.
These diffusors fit to the original parts, even it is quite a tight fit.
These prices have included 19% German VAT, shipping comes on top. Buyer pays custom duties if delivered to the UK. Payments can be made to my German bank account, my UK – bank account or via Paypal.
Please email me for availability:
grischa@hertenstein.info
Thank you.
Grischa"
#91 Re: New Reproduction Parts for E-Type's
Post by Heuer » Wed Mar 24, 2021 3:41 pm
New product from SNGB:
Hi David,
Hope all is well.
Quite a significant new product for us is the V12 exhaust manifolds which we have retooled from scratch using modern technology and we are really pleased with the results. These were a product we originally made probably 25 years ago and the tooling we were using was well past its “best before” date but these new ones have come out really well. Its part number C39109 and C39110 – they are showing as out of stock online at the moment only because we have quite a number of backorders but available stock will be with us next week.
https://www.sngbarratt.com/English/#/UK ... 0c39109%60
All the best
Julian
Locked Previous topicNext topic
