I bought another E type
You need to talk to Simon SEJohnson95 and Dave 44DHR:
viewtopic.php?t=4166
I have an 1/8 as well, but I think it is Revell. Still undecided about building it or leaving it in the box ...
Pim van der Schaaf
1E34261
1A33630BW
1E34261
1A33630BW
Will you try for a LHD to RHD conversion?
#7 Re: I bought another E type
I got one about 10 years ago and its still in the box, one day when I'm not rebuilding real cars I'll have a go at it.
Umm, I think this is going to be more difficult that a real one! getting the paint detail correct is going to require new equipment! just saw the price of a miniature spray gun and compressor. ouch. Maybe it will stay in the box as well.
Nah! Use a rattle can. Worked for me.andrewh wrote:Umm, I think this is going to be more difficult that a real one! getting the paint detail correct is going to require new equipment! just saw the price of a miniature spray gun and compressor. ouch. Maybe it will stay in the box as well.
My build process took some time and is a story in its own right. One day...., maybe.
richard btype
#10 Re: I bought another E type
Andrew
As well as the new car a new property, very nice?.
3.8 FHC Chassis no: 860403
DOM - 11th April 1962
Also
4.2 FHC Chassis no: 1E32173
DOM - 12th December 1965
Also
SEJohnson95
#11
You can buy the RHD dash panels now and then it's just a case of swapping everything round in the engine bay. OK if you build things up from scratch anyway. I had to melt my dash with a knife somewhat crudely and reform it, but the effect is the sameGfhug wrote:Will you try for a LHD to RHD conversion?
Richard painted the car with the same gun that was used to paint the real thing, lacquered it, wet flatted it and everything. You can use real car polish on it then, smells lovely!
viewtopic.php?t=5012&postdays=0&postorder=asc&start=10
also:
You'll not see those two together again as one of those has changed hands, and it ain't the little one.
Simon Johnson
#12
Thanks Simon, now do they have an S2 FHC or an S1 to S2 conversion kit? :D
My concern with rattle cans is the metallic flake will come up too large for the model, not even sure I can get OSB in a can. When I used to make models as a lad they fell to pieces a few years later. I rather hope glues have moved on a bit!
Simon, missed your post somehow. Your model looks stunning . I guess I can use my miniature spray gun that I have just need to get started. Did you hand paint all the little bits and if so where did you get your paints? Humbrol or Revell, oh and which glue is the best for longevity and quick fix? Thanks andrew
beautiful! Now thats what I need to get mine looking like. Did you use the same paint as the full size car? very nice indeed
If you want to do it full justice, it's worth having a trawl through HiroBoy's website. They can either mix paint from the manufacturer's paint code:
http://www.hiroboy.com/Custom_Paint_Mix ... --866.html
Or you can try to locate something from their existing range that looks close:
http://www.hiroboy.com/Cobra_Viking_Blu ... -2604.html
Beautiful stuff to work with. Airbrush only though, and you'll also need to lay down a good quality coat of the appropriate primer first (you also need to clean up afterwards with cellulose thinners, which is evil stuff!)
Loads of detail parts too on that site if you want to add additional realism or finishing touches.
1969 S2 FHC - 1R20258
2008 Caterham Seven Roadsport
thank you Simon. I will have a trawl though this evening. Much fun ahead!
Now we have whetted the appetite again for these amazing models and what can be achieved - not to forget this post which Simon replied to initially :-
viewtopic.php?p=51409&highlight=#51409
Cheers,
Cheers,
Dave Rose
1967 Series 1 4.2 FHC
You are right Andrew, it's the original OSB. The model was painted with the real car in a bodyshop. Great model.
A german modeller made incredibles E-Type with this kit.
http://www.finemodelcars.info/index.html
