Every time I carry out any work on my E Type I have to refer to my Triumph TR6 Workshop Manual to find what torque setting I should use to tighten the fixing. For example front Caliper attachment 7/16 UNF 65 lbf.ft. This manual contains a torque setting for every fixing on the car.
Is there a similar document for the E Type?. The Haynes Manual ignores the subject totally, and the document on this Forum I find difficult to understand.
Confused requires Help.
Torque Settings
Mark Gordon
From the E Type Knowledge Base:
http://dl.dropbox.com/u/8496016/Torque% ... 281%29.mht
or
http://dl.dropbox.com/u/8496016/Torque%20settings.doc
or
Mark,
Can you please explain how to interpret this document please.
Roger
Roger
Roger McEwen
S2 FHC Green
Triumph TR6 Mimosa
S2 FHC Green
Triumph TR6 Mimosa
Hi Mark...To answere your original question no not to my knowledge..as you can see those pages are only suggested figures and its not a jaguar document......the Jaguar workshop manual does have some torque settings but not for everything........for front caliper mountings both S1 & S2 cars the manual says to lock wire the bolts and no torque value.......Personally I just follow the manual...nothing has fallen of yet...I dont rate the haynes manual much.....all the jag ones are in the knowledge base
Its a mht file, you can edit it and rename it to html... or convert.
I posted a pdf version here but I take no responsibility for it... 8)
http://www.docdroid.net/as8UtmA/torq.pdf.html
61 OTS Black on Red, 62 FHC nuts & bolts resto on the way to OSG & Matador red.
As Steve wrote, it is just a recommendation and not Jaguar specific. I would only use it on bolts I could not find "E-type specific data" for.
I (Google) have just found a list of Torque wrench settings in the Jaguar Series 3 Service Manual on our Knowledge Base!!
Except for the engine I am assuming that the rest are applicable to the Series 1 & 2 as relevant.
Roger
Roger
Roger McEwen
S2 FHC Green
Triumph TR6 Mimosa
S2 FHC Green
Triumph TR6 Mimosa
I have a copy of Machinery's Handbook. For the lions share of fasteners fasteners (basically if the part number begins with "UF" or "UC" torgue is not a critical value - tight enough that it can't shake loose is fine (I have a calibrated elbow/wrist). For the cases where the manual doesn't specify a value and it IS an situation where torque does matter (caliper halve bolts and such) I just look up the value for that thread, grade of bolt/finish, and material combination. If you google a bit there are tables for the typical threads, bolt grades and finishes, and materials (Steel, CI, Al, Brass, Bronze).
Andrew
Andrew
