#1 4.2 cylinder head water holes
Posted: Mon May 30, 2016 10:19 am
As some of you know, I'm in the process of removing the Str?mbergs.
Two hours work, and voila!
So, now what?
Freeze plugs in the cylinder head? Could it be that easy?? :)
Also. I need some new water hoses and a thermostat housing. Are these readily avalable?
On the inlet, there is also a small take off with three holes. Temp sensor?
So, now what?
