Actually there are three things. I also don't like that the down pipes are much lower than the rest of the system - more than an inch lower.
The slot under the car into which the silencers fit is precisely 16 inches wide. The trouble is that the silencer staps are also 16 inches wide. This distorts the rubber hangers to the point they often fail. Here are some photos.
Here is the silencer strap, which is more than 16 inches wide (before wrapping around the silencers).
Here is a new rubber hanger. This particular hanger delaminated on initial fitting and had to be replaced immediately.
And here is a hanger distorted by the ill fitting silencer strap.
Clearly something is not quite right. Question is what have others done? Modified the straps? Cut the hangers? Forced it all to fit?
As for the sound, I'm sure I recall one owner had modified an exhaust for a coupe to fit, thus generating the unique E-Type growl only produced by twin exhausts.
