#1 Found a Lucas 2FP fuel pump in my 69 2+2.
Posted: Tue Nov 15, 2016 2:11 am
Hello everyone. I'm a new member, vague at best when it comes to forum navigation and not too good with computers in general to be honest, but I'm steadily finding my way around. It's like discovering a new magazine to me, only much better. So much information and presented in a way even I understand. Fantastic. I hope I'm posting this in the correct place, it's not a query of sorts, I just thought it would be interesting.
I have a 69 2+2 that I've owned and regularly driven since 1978. I am the second owner and until recently thought I knew more or less the cars entire history. I removed the fuel tank to replace it while carrying out some other repairs and when I removed the plate on top there was a Lucas 2fp fuel pump fastened to the underside of it.
My car has always had an electric pump, and so I thought, the original tank.
The pump is stamped with 78387 E and what appears to be a date 12 /5/63. it has locking wire with a lead seal squashed onto the join fastened to what look like two adjusting devices, and a braided hose with electrical cable inside which has been cut off level with the brass fitting nut on the end of it. On the bottom there is a curved copper pipe with a gauze strainer on the end and it fastens to the body with a banjo bolt with copper washers each side. The two rubber ? bushes pressed into the eared lugs are in remarkable condition, one has what looks like earthing or anti static metal tabs folded over it, whatever they are made of, it looks like you could just go ahead and reuse them they've lasted so well. The tank was rotten and pinholed and to my amazement covered in large welded patches at two corners underneath. The car was entirely rust free when I bought it in 78 with only 17,000 miles on the clock. The old gent I bought it from back then had maintained it almost obsessively and handed me receipts with the paperwork for everything from having a new key cut to a replacement exhaust back box. There was no mention of a fuel tank swap. It's just a mystery to me how the car ended up with an old patched up tank from an earlier car, and what could have happened to the original with such a low mileage ?
I also found two old half crowns and a threepenny bit under there when I eventually got it out, not an easy job, but the sight of large shiny coins, even though they are worthless now, somehow made it rewarding.
My 27 year old son couldn't believe we used to carry such heavy things about in our pockets all day.
I'm in the middle of changing the picture frame at the moment and will be searching the forum for anything in relation to that before I start bombarding you all with endless questions.
cheers.
cheers.
