Managed to aquire a 4.2 inlet manifold, needs a little TLC, threads in the casting for water, vacuum outlets and temperature gauge switch need cleaning with a tap running through them, anyone know what thread sizes these are?
Many thanks in advance,
https://i.imgur.com/YFvdGt9.jpg
https://i.imgur.com/C6GUboZ.jpg
Triple 4.2 SU inlet Manifold
#2 Re: Triple 4.2 SU inlet Manifold
Had mine helicoiled . 5/8 BSP from memory.
Tim
Tim
#3 Re: Triple 4.2 SU inlet Manifold
Hi Tim thanks for your reply, would that be for water & vacuum outlets?
#4 Re: Triple 4.2 SU inlet Manifold
I only had the water outlet done. Sorry should have mentioned that .
#5 Re: Triple 4.2 SU inlet Manifold
Hi Tim many thanks it’s the water outlet on mine as well...
#6 Re: Triple 4.2 SU inlet Manifold
I would just like to confirm thread sizes for the above, Heater and Vacume Outlets 3/8 BSPP, Temperature Gauge Sender 1/2 UNF, hope this be useful for someone in the future.
Julian.
Julian.
