Insulation on exhaust hoses
johnetype
#21 Re: Insulation on exhaust hoses
Post by johnetype » Fri Apr 19, 2019 8:15 am
Yes but wouldn't you have had the fire whether the pipes were wrapped or not? If hydraulic fluid sprayed in the direction of the exhaust pipes it would catch fire.
+1 for silicone brake fluid.
1969 Series 2 FHC
66an
Sweden
#22 Re: Insulation on exhaust hoses
Post by 66an » Fri Apr 19, 2019 9:34 am
No one can be sure if the fire had started anyway. But remember the pipes are hotter if they are wrapped. And the wrap soak up the oil. Its like a flambeau( correct word?)
My engine was not what I call hot when this happened either. I was idling in a traffic jam for while when this happened.
Mats
1966 S1 OTS
MikeMilton
#23 Re: Insulation on exhaust hoses
Post by MikeMilton » Fri Apr 19, 2019 3:12 pm
This is another argument for a solution that keeps the surface temperature of the pipes lower. Ceramic coatings (which can be applied both to the interior and exterior of a header (or manifold or pipes) does exactly that.
While not a guarantee, obviously there are circumstances where the surface temp is high enough to start a fire, these situations are fewer.
Just an old guy living by a lake - with a 1969 E-Type FHC, and 1962 OTS
