Diff oil change & flush???
rossco_j
#1 Diff oil change & flush???
Post by rossco_j » Wed Jul 03, 2019 12:22 am
Having removed the diff plug & filler successfully, I'm wondering should I flush the diff housing with something before adding the new oil. The oil appears to be relatively clean but the car has sat for a couple of years before I acquired it. What would be a suitable flushing product??
Ross
1972 Series 3 E Type 2+2
1972 MGB GT
1965 Mini Cooper
1954 Austin A30
https://rossjohnsonphotography.zenfolio.com/
Geoff Green
#2 Re: Diff oil change & flush???
Post by Geoff Green » Wed Jul 03, 2019 2:05 am
If you drove the car recently, even only a mile, I would not flush because of removing proper oil from the limited slip clutch packs and coating the clutches with a non- lubricant. Just fill with the correct fluid including limited slip additive.
