Post
by Tom W » Sat Nov 30, 2019 8:55 am
Firstly, unrestricted flow is bad. Don’t run without a thermostat, you’ll never get the car to warm up.
If you don’t want a thermostat, then you need to replace it with a bung with a hole drilled in. To size the hole will require some experimentation, and then you’ll only have the right cooling for the ambient conditions on the day you get it right. Race cars sometimes run this setup (presumably for reliability), but then racers do a lot that doesn’t work on a road car. So, for a road car, you want a thermostat.
The function of the thermostat and bypass seems very miss understood. It’s not an on/off switch that opens part way through warm up and stays open for ever more. It’s a feedback loop to maintain a steady engine temperature. It works as follows:
Imagine the engine is up to temperature. The thermostat is open, and water flows into the top hose and through the radiator. The water is cooled by the radiator. The amount of cooling is dependent on radiator efficiency, the amount of air flowing over it, and the temperature of the air flowing over it. So there is now cool(er) water entering the water pump from the bottom hose, ready to pass through the engine again. The engine has no control over how cool this water is, that’s down to radiator efficiency and ambient conditions. Imagine it’s very cool by the time it reaches the water pump. After it’s lap round the engine, it reaches the thermostat where it’s still not warmed to operating temperature. This cooler water causes the thermostat to close, shutting off the top hose and opening the bypass. The cool water now passes directly back to the water pump for a 2nd lap around the engine. This time round, it reaches the thermostat above operating temperature, so the thermostat opens again, and so the feedback loop continues. In reality it’s not so exaggerated, the temperature doesn’t fluctuate, and the thermostat adjusts as necessary to maintain a constant temperature.
Now, e types, and other old cars, suffer because the rad doesn’t always have the capacity to over cool the water, so the thermostat is pegged wide open and the temperature continues to climb.
If you fit a thermostat that doesn’t block the bypass when it opens, you’ll always get some water that doesn’t pass through the radiator and the car will be more likely to overheat.
Tom
1970 S2 FHC
