Correct in a 3.8?
#1 Correct in a 3.8?
Are these two pieces standard equipment on a 3.8 October 1962? Picture is from Jonathan Wood "Jaguar E type - The Complete History", and referred to the 3.8, but I haven't found them but in the 4.2.
S1 FHC 3.8
#2 Re: Correct in a 3.8?
Clausager Factory Original E Type book page 21:
Change No. RA 7324 June 1964 Lifting brackets added to cylinder head, some head studs lengthened...
Does that help? A very good book to get if you're trying to be as original as possible (with Haddocks (?) books as well)
#3 Re: Correct in a 3.8?
It helps indeed, thanks a lot. I have the Clausager but I did not see that reference, thank you for your help
S1 FHC 3.8
#4 Re: Correct in a 3.8?
You could use the factory fit 3.8 section of the forum...lots of info there.....Steve
#5 Re: Correct in a 3.8?
…. This, in turn, came from the Jaguar Spares Bulletin No. A.146 (Engine) published in August 1964. Copies of these are in the Knowledgebase section of the Forum. This confirms that it is from Engine Number RA.7324
The Service and Spares Bulletins are an excellent source of information as to when changes occurred on the cars. Most of the books on the market are quoting from these when they refer to when changes were made.
1964 S1 3.8 OTS
1964 S1 3.8 OTS
#6 Re: Correct in a 3.8?
My April 62 e type has them if that helps
Tony (E typed)
Tony
Tony
#7 Re: Correct in a 3.8?
Hi Tony....fitted at the factory....or later....Steve
#8 Re: Correct in a 3.8?
It was my understanding that the longer studs and engine lifting brackets were fitted from June ‘64
My March ‘62 OTS has them, yet engine block is original but the head may have been changed ..probably added later
Robbie
Robbie
